Results 1 to 12 of 12
    Mga sir, meron akong nakitang bulb (yellowish) just beside the projector head lamp f the Toyota Fortune 2016... What is that? What is the part number nya? Can I change that to a yellowish led bulb (para mas maliwanag)?
    Dec 2019
    Quote Originally Posted by attyallanlatras View Post
    Thats possibly either the park light bulb (closer to the middle by the grill) or the signal light bulb (outer side near the fender)
    Etong naka on na amber orange is the parklight, which i changed to a super bright LED.
    Sir, if parking light yan, bakit sya umiilaw kahit neutral at hindi sa parking ang knob (A/T) ko? Sir sa mga naka LED lights na fortuner, hindi ba ito yung equivalent sa mga small ledlights na laging naka on even during daytime?
    Quote Originally Posted by hdj80 View Post
    Jan 2008
    Park light po.. not parking light! Yung park light umiilaw pag nilagay mo sa park yung headlight stalk switch.. hindi yan sumusunod sa stick shift
    Dec 2019
    Also, in addition, if you place your headlight switch in A (automatic) the park light turns on in overcast or dim lighting.
    Thanks sir... Does this turn on during driving? sorry for my noob question...hehehe
    Dec 2019
    If your headlight switch is off it wont turn on but if you leave it on automatic it will turn on during overcast or low light situations.
    How to leave it on automatic? Sir since you said that you changed this to LED, is it yellowish led light? If so, what is the number? Maliwanag din ba like the headlight? I want it to help in providing more light during night driving...
    looks like we all have the same car and model, which is the Fortuner G model.
    i don't think upgrading the park light to LED will help to provide more light. because as far as i know, that is not the design for the park light.
    i saw a post in one of the fortuner groups i joined in fb, someone who has upgraded to an HID retrofit, which costs 23k.
    or you can upgrade to a V headlight assembly, but i don't know if will be significantly better than upgrading to LED bulbs.
    or you can remove your front tint, or just use a lighter tint.
    atty,
    i believe the car owner's manual explains what those lights are.
    if park lights, then upgrading them will probably not result in significant increased driving brightness at night, because they were not designed for that.
    i have two near-identical cars. one has light front windshield tint, the other has none.
    i am aware of the diminished brightness, that light tint gives me.
    it is not "insignificant", as some might want others to believe.
    I have finally resolved my issue through upgrading my foglights using LED from Ledworks through its H11 X9 na 4300k (yellowish)...
Pls help me identify the bulb just next to the projector head lamp of the Toyota Fortuner 2016
