Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 104
    May 2010
    just this afternoon while driving home, i saw a banner in one of the Petron stations here in Sucat stating "100 octane" together with their blaze banner.
    Has anyone tried it already? wanna try it na pero i still have the old 96 octane blaze in my other car's tank. Ubusin ko muna then i'll try it.
    Isn't 100 Octane rating too high ? Besides, unleaded would already do on most cars.
    Baka naman race gas yan or whatever.
    Jul 2010
    pwede pa yan sa mga de karburador......sa panahon ngayon puro Electronic fuel system na, sayang lang ang pera kahit magtaas pa ng octane ang sasakyan....
    http://www.topgear.com.ph/news/is-pe...00-octane-fuel
    Is Petron about to launch 100-octane fuel?
    We've received a tip that Petron is set to launch an ultra-premium gasoline fuel with an octane rating of 100. This is certainly great news for those who drive high-performance cars, whose engines' higher compression ratio requires high-octane fuel. Petron's current premium gasoline fuel, Blaze, has an octane rating of 96.
    When we asked Petron about the tip, we were told they could give "no comment until Sunday." Which, as far as we're concerned, is the equivalent of answering the question in the affirmative.
    Octane rating is an important concern among owners of high-end cars with engines designed for performance. It refers to a fuel's antiknock properties. Knocking is that pinging sound made by an engine due to improper ignition. Severe knocking can actually damage your engine's pistons.
    Big-displacement and powerful engines have higher compression ratios, making them more susceptible to air/fuel mixture detonation (which results in that knocking sound). Imagine a piston needing to do more work to deliver the high output of a performance engine, and you'll pretty much understand why the process is more prone to faulty ignition. High-octane petrol, which ignites longer, solves this. The higher the octane rating, the more optimum the performance of the engine will be, allowing the latter to achieve its maximum power potential while also doing wonders for fuel efficiency.
    If you drive a Nissan GT-R, a Mitsubishi Lancer Evo X or a BMW M5, we suggest you check out the nearest Petron station this Sunday.
    Yep ... I instantly made a research about it and was about to edit my post.
    And yep, it is indeed 100 octane.
    Now, unless your car requires something 98 octane or higher fuel ( i.e. STi ) then, using 100 octane would probably be useless and just a waste of money. I would highly doubt if using high octane gas would give you a bigger difference in HP if used on stock engine though I'm not saying that it is impossible.
    If I'm not mistaken, 50+ yung price range nito. Expensive.
    And yeah, I think using higher octane fuel gives you poorer fuel economy. :dunno:
    May 2005
    Did they increase the price? I use Blaze just to avoid ethanol.
    Mga drivers ng performance cars ang target nito IMO. Pati na rin yung modified/tuned engines etc..
    Jul 2010
    mag-unleaded na lang kayo......propaganda lang yan.....
    Jul 2010
    Maikwento ko lang bro, Dito sa saudi, ang daming Sports car kang makikita sa daan....pero 2 klase lang ang gasolina 91(unleaded) at 95.
    E napakamura ng gasolina dito at bakit wala yang mga yan 100RON na yan dito? ano ibig sabihin nito? mga oil companies sa atin, mga sun and the beach talaga...!!!!
    Yup. 51.50 daw according to one forum na nakita ko sa google.
    Jan 2009
    and useless for most cars. dagdag bayad na walang dagdag performance.....teka dagdag gastos pero porma lang? pang riceboys lang ata ganuon!
  12. #12
    Para sa mga mahilig kumalikot nang makina 'to. You can play around with your engine timing, and time your combustion earlier. More power. Pero kung stock ka rin lang, mag regular unleaded ka na lang.
    Jul 2010
    Unleaded gas - 5.18pesos per liter
    premium gas - 10.36 per liter
    Napakamura ng gasolina dito, pero bakit hindi magtaas maski 96 o 97 or 100RON ang Saudi Aramco?
    kasi useless lang kahit taasan pa, its just a waste of money para sa mga mamamayan...
    Aug 2005
    for our cars, i go for the chepest unleaded gas that meets the RON requirement of the car. kaso Ethanol blended na. so we use Caltex Gold dito sa sta rosa at hindi pa ito E10, tapos 0.60 petot lang more expensive than silver.
    kaso pag Ethanol blended na lang ang available, caltex silver na lang.
    majority of cars would not need 100 RON fuels in their cars. marketing hype for me. the market for 100 RON fuels is very small.
    Jul 2010
    There are instances where a higher-octane gas will be better for your car -- such is the case with older engines. For older engines, high-octane gasoline is usually not required but can make your car run more smoothly. For newer cars, your best bet is to follow the manufacturer’s recommendation.
    http://www.consumertipsreports.org/t...ctane_gas.html
    Nakupo. Lalo lang mamahal yung kinakarga namin sa CR-V
    Back to XCS!
    Pero this is worth trying sa long drives.
    *Edit: Eto nanaman ang oil companies. Tingnan niyo, di magtatagal gagaya ang Shell. Tapos Caltex.
    Bakit kaya hindi muna nila asikasuhin ang EURO IV Diesel?
    Quote Originally Posted by desert fox View Post
    Ewan ko sir. Base lang yun sa mga nababasa ko na the bigger the engine, iba yung compression nya (?) basta parang ganun therefore it requires higher octane fuel.
    Anyway I'm not an expert. As I said based lang sa mga nababasa ko.
    100 Octane would be the best fuel for the GDi cars here in the Philippines..
    Pwede na ako mag Sonata F24 GDi :naughty2: Nyahahaha
    Jul 2010
    oo tama ka bro the bigger the engine,the higher compression ratio....
    May 2010
    i think it's really worth a try. I don't know if it's psychological pero when i'm using Blaze, i feel a better response compared to XCS. But it's only a little bit of difference compared to the price your paying for.
    Me too. i use blaze just to avoid those E10 blended fuels but if there's no other choice, welcome E10 fuel. grrr...
    Back to XCS!
    Tama si Sir. bakit hindi na lang diesel? where in fact diesel cars equipped with CRDI are now everywhere?
Petron BLAZE 100 Octane na!
