Page 7 of 34 FirstFirst ... 3456789101117 ... LastLast
Results 61 to 70 of 333
  1. #61
    mmm... any side effects if you put too much acetone?
    #62
    Quote Originally Posted by ILuvDetailing
    I assume you mean more than the recommended dose. Less and less milage. Possibility of ping and knock (but the amount needed would be very big).
    Sep 2004
    #63
    According to the graph GH posted, the % gained decreases, add too much and it becomes a negative gain - degrading effect.
    #64
    magpapahanap ako ng pure acetone. we supply meds and medical supplies, kaya baka may makuha tayong pure acetone
    #65
    what would be handy (for me) will be a small supply of 60mL bottles, each enough for one dose of a full 40L tank of gasoline. That way I could pre-measure the amount of acetone and wouldn't need to bring a graduated cylinder to the gas station everytime I have to gas up.
    Feb 2005
    #66
    sound promising, from what I've read on the net. apparently it is also a component for those who mix/blend their own fuel for drag purposes
    #67
    Quote Originally Posted by zman
    I am aware of that. But currently I am focusing on the milage extending property of acetone in gasoline.
    BTW, acetone blended into gasoline will not automatically increase your engine's HP rating. Its just like using hi-octane gasoline, you need the proper engine (or engine mods) to take advantage of it.
    #68
    All of this sounds good! Go Go GhostHunter! I hope that your experiment shows favorable results (mileage wise) coz I can sure use the savings for my truck! Good luck!
    #69
    [SIZE=4]Tsikot.Com Acetone/Gasoline Test 2005[/SIZE]
    The Car: 1999 Toyota Corolla 1.6 GLi A/T
    Typical Milage: 5.5 to 6km/L all city driving with a/c always on.
    Typical Destinations: Cubao, Makati, San Juan, Mandaluyong, Manila.
    Amount Acetone added: 60 mL (measure via graduated cylinder)
    Fuel Used: Shell Unleaded (approx 91 octane)
    Gas Station: Shell * Ortigas/Connecticut, San Juan.
    Status:
    April 07, 2005
    Today I filled my tank with 60mL of acetone and filled the rest of the fuel tank with Shell Unleaded gasoline.
    After half a day and 12km, there was no difference in how the car behaved in starting, accelerating or idling.
    April 11, 2005
    so far I have used up about 1/4 of my tank of acetone treated gasoline. Typically I get about 60 to 70km at this point with "normal" gasoline. I got slightly over 80km (83km to be exact). That is about a 30% improvement assuming the basis is 65km * 1/4 tank consumed.
    Note: At this point, the "gains" are unofficial because any car's fuel level guage can be relatively inaccurate. The official km/L will be when I fill up my fuel tank again. Based on current consumption, it will be at the end of the week.
    #70
    Cool, TIA for testing this out... :D
Fuel conservation using acetone...
