Results 21 to 30 of 333
April 7th, 2005 12:52 PM #22
some fun things that acetone will do with your car:
1. Pre-ignition of the fuel
2. Damage to fuel lines from normal acetone properties
3. Water in acetone condenses inside cylinders, or rusts out your gas tank
4. Ketones and other oxygen-bearing organics like ethanol have been known to produce carcinogenic incomplete combustion products in exhaust.
April 7th, 2005 12:52 PM #23Originally Posted by theveed
April 7th, 2005 12:57 PM #24Originally Posted by mazdamazda
As for water, it pure acetone, not acetone and water mixture.
ethanol and acetone is different.
Acetone (CH3COCH3)
Ethanol (CH3CH2OH)
April 7th, 2005 12:59 PM #25Originally Posted by ghosthunter
from another experiment... a guy soaked his fuel lines & gaskets in gasoline-acetone mixture... no fuel line damage although the gaskets slightly expanded.
- Nov 2002
- 179
- Nov 2002
- 179
April 7th, 2005 01:23 PM #28precise measurements, via graduated cylinder, on the amount of acetone to be applied to the nail.
April 7th, 2005 01:51 PM #29Originally Posted by theveed
35% savings?...not bad. hintay-hintay muna sa resulta.
April 7th, 2005 03:28 PM #30
since my car had less than half a tank of gasoline left, I went ahead and filled up 60mL of acetone and then a full tank of gasoline. I hope this would ensure a better distribution of the acetone thoughout the gas tank.
I measured the amount of acetone via graduated cylinder. I probably looked weird to the gas pump guy.
60mL is a touch over 2oz.
I've driven about ten kilometers since my fill up and so far nothing out of the ordinary has happened.
I hope they improve the interior a bit. The current is IMHO low-rent for the price.
2025 Nissan Kicks
