Results 811 to 820 of 4200
April 10th, 2007 09:47 AM #811
The best auto-LPG kit is the sequential injection LPG system, which basically a individual port fuel injection system for LPG. It even gives your engine a slight boost in power as compared to running on gasoline. Downside is it cost at least twice as much as the typical LPG system available at NAIADSS or other LPG installers.
NAIADSS price for 1.6L EFI conversion is around P28K.
You have a budget in mind for your LPG conversion?
April 10th, 2007 10:02 AM #812
best to have the tank draining done at the LPG service stations and not DIY. So far I haven't done a system drain. Based on my computations, I should be due by August of this year.
But putting vinegar inside the tank... how does that make the LPG less volatile? Won't it just lead to rust forming on the inside of the tank and possible acidic fluid contamination to the rest of the LPG system?
April 12th, 2007 05:28 PM #813
- Sep 2006
- 106
April 12th, 2007 06:01 PM #814
April 12th, 2007 06:01 PM #815
April 12th, 2007 06:05 PM #816
The LPG kit for EFI engines and carb engines are almost the same (given the Korean type conversion kits). The difference is the injector bypass box which disables the engine's fuel injectors if you are running on LPG. If you dont have fuel injectors, there is nothing to bypass.
There is the Italian EFI LPG kit that costs at least P60K. I dont think you can fit that to a carb engine either because I think it takes the stock injector signals for fire it's LPG injectors.
April 13th, 2007 09:09 AM #817
- Apr 2007
- 7
April 14th, 2007 07:47 AM #818
April 14th, 2007 10:02 AM #819
- Apr 2007
- 7
April 15th, 2007 07:17 AM #820
lotus elise all the way! 2004 edition
Lotus returns...
