Page 80 of 420 FirstFirst ... 307076777879808182838490130180 ... LastLast
Results 791 to 800 of 4200
    #791
    Quote Originally Posted by afg598 View Post
    thanks! how about EFI conversions?
    not sure, check if your LPG kit has the big cylinder thingie that has four hoses, two routes hot water from the radiator and back to it and two others are for the LPG.
    If you do, then you'll need to drain it too at the proper intervals.
    does the lpg pass through the same injectors that the petrol uses?
    nope. EFI type LPG systems have their own injectors.
    Non-EFI type LPG systems use a carb type donut-like adapter fitted at the engine's air intake.
    #792
    so how do they do it, bore new holes on the cylinder head to accomodate the new injectors?
    #793
    yes and no.
    They would drill new holes on the engine intake runners for the new injectors.
    #794
    yes and no.
    Thanks.
    I just have a peculiar observation with my conversion. Mine is a 1.3L carburated engine. before conversion, i was averaging 7.5km/l city driving on petrol. after conversion, i am now averaging 10.3km/l which contrary to all i have read about getting 10% lower km/l on lpg as compared to petrol.
    i haven't changed my driving route, time or habits. i asked a friend of mine who had a similar vehicle and he tells me that he was also getting 7-8 km/l on petrol city driving.
    Aug 2004
    #795
    Most likely the newer injector/carb system of the LPG is more efficient than your old carburator.
    Old carburated engines are notoriously inefficient... especially if they've racked up a lot of kilometers, already. You might want to clean your carb or have the jetting checked... see if you can get it close to the efficiency of the LPG kit...
    #796
    22.50 dyan sa auto lpg along shaw boulevard before you turn to nueve de pebrero
    i just had my oil change and medyo nag improve ang fuel efficiency ng lpg system
    but i still average around 6.7 km per liter of LPG mixed city and highway driving kapag highway mga 8 km per liter
    #797
    I tried using a carb cleaner several times during change oil/tuneup but the consumption remains the same. Maybe the jets need adjustment but I don't want to spend anymore $$$ on it. I'd rather use it to by LPG fuel instead....
    #798
    A LPG system isn't cheap even if the fuel is... it will cost you PHP24K (and up) for a kit.
    #799
    Hello to everybody...
    I'm new here sa tsikot...
    Mga ka-tsikot na LPG users...
    Toyota Carina (1450cc) 1987 carb. type ang pina-convert ko sa AMBIent QC. * P24k. Ok naman takbo ng kotse. Average fuel consumption 8km/li.
    Tanong ko lang kung meron dito gumagamit ng AIE o Air Intake Equalizer na gadget? Ok ba performance sa LPG system?
    Salamat sa response...
    #800
    Dito pala sa munoz may LPG station ng Clean-Fuel...* P22.70/li.
    May Free tune-up pa for every P1,000 fuel purchase...(carb. type vehicles only) up to 9pm. FYI.
Auto-LPG Conversion Thread
