Results 3,821 to 3,830 of 4200
January 31st, 2012 06:15 PM #3821
- Jun 2006
- 1,139
February 1st, 2012 12:01 AM #3822Lets say na 7mm long ang injjectors while ang thickness ng intake manifold is 5mm. yung difference na 2mm is naka portrude ngayon sa luob ng manifold. That was the case in a crv,, ewan ko lang sa innova. Intake runners should be smooth as possible for free flowing air.
- May 2010
- 186
February 1st, 2012 10:55 AM #3823
- May 2010
- 186
February 1st, 2012 11:07 AM #3824
same practice din ang ginagawa ko. mga 500 meters ata before mag auto-switch to lpg pag naabot na desired temp. every weekend gas mode. karga gasoline 500 every 2-3weeks.
that's my initial thought din na baka effect lang ng drive by wire but comparing it side by side with gasoline parang hindi lang siya sa drive by wire e. pag naka lpg ako kasi, pag pinitik ko yun accelerator from stand still, yun tunog ng makina ay parang hangin yun pumapasok (hindi ko lang alam kung ano technical term nito). pag naka engage yun gear like first gear from stand still parang maramdaman mo na magshake unti engine pati yun stick shift pipitik siya. paghindi mo nacontrol gaano yun clutch possible mamatay makina. kaya hindi ko siya pinipitik or biglang tapak even parang ganon naman nakasanayan natin both sa gasoline and sa diesel. phasing na tapak lang ginagawa ko na.
nashare ko lang ito at baka naexperience na din ng mga naka lpg at makapagbigay ng tip kung paano naayos. kung hindi maayos ok na din naman sakin since satisfied na din naman ako sa kit ko both power and economy.
thank you again.
- Jul 2008
- 102
February 1st, 2012 04:07 PM #3825Hi guys! would like to update everyone on the price increase of Auto LPG effective today. Pump price is at 34.90 on most stations. Winter time in EU drives up the world price.
- May 2010
- 186
February 1st, 2012 04:51 PM #3827
February 1st, 2012 06:52 PM #3828
I just had filled up my LPG tank. I also miss those sub-P20/L LPG days.
- May 2008
- 61
February 6th, 2012 04:08 PM #3829Where did you have your fuel lines cleaned? Did they flush out the gas lines with a solvent? My car runs great on lpg but can't seem to keep the engine running when on gas. I already replace the fuel pump, fuel filter and distributor, cleaned the intake manifold, changed the spark plugs but the problem still persists. Parang nalulunod pag gas gamit ko hanggang mamamatay nalang yung makina. I was thinking baka yung fuel lines nagbara na din.
February 6th, 2012 06:42 PM #3830
lotus elise all the way! 2004 edition
Lotus returns...
