Quote Originally Posted by Louga View Post
*mile2 - BFC coil na din yun sakin when i asked them. hindi kaba nakakaexperience na issue ko? actually ok man talaga power ng engine ito lang talaga yun natitirang issue ko. naraised ko na din ito sa kanila pero hindi naayos e. last recommendation ay palit/swap injector papunta don sa 2 injectors per rail para masiksik siya closer. pero kung ganito din setup sayo at same lang naman tayo ng kit, baka hindi lang ito injector position issue.
ipatignan ko na lang kay xoom baka magawan niya paraan.
another question not related to my issue: nagpalagay kaba cut-off relay innova mo? sakin kasi wala pero follow ko lang lage yun advise dito sa forum na keep 1/4 gasoline sa tank para iwas sira sa pump
I don't remember having a cut-off relay. I usually run around 200 meters slow and below 2K RPM every morning going around my area to pick up my passengers which is still on gasoline, then hit the highway on automatic switching to LPG passing the 2K RPM. Same with me for 1/4 gasoline reserve as minimum.
Yung issue mo na walang power during sudden quick stepping on the gas pedal, yes I do experience them once in while but I already learned to dealt with it since our ride has electronic gas pedal and response has delay even on pure gasoline. You just need to prime it a bit before stepping hard.
