Page 192 of 211 FirstFirst ... 92142182188189190191192193194195196202 ... LastLast
Results 3,821 to 3,840 of 4201
    #3821
    Quote Originally Posted by Mile2 View Post
    I don't remember having a cut-off relay. I usually run around 200 meters slow and below 2K RPM every morning going around my area to pick up my passengers which is still on gasoline, then hit the highway on automatic switching to LPG passing the 2K RPM. Same with me for 1/4 gasoline reserve as minimum.
    I also practice this in the morning (cold start); i run on gasoline and keep the rpm below 2K and auto switch to LPG when i hit the main road outside our subdivision. I load up around P 300-P350 worth of gas every two weeks.
    Jun 2006
    #3822
    Lets say na 7mm long ang injjectors while ang thickness ng intake manifold is 5mm. yung difference na 2mm is naka portrude ngayon sa luob ng manifold. That was the case in a crv,, ewan ko lang sa innova. Intake runners should be smooth as possible for free flowing air.
    May 2010
    #3823
    Quote Originally Posted by shibby75 View Post
    ahh ok. yun pala ibig sabihin non. thank you
    May 2010
    #3824
    Yung issue mo na walang power during sudden quick stepping on the gas pedal, yes I do experience them once in while but I already learned to dealt with it since our ride has electronic gas pedal and response has delay even on pure gasoline. You just need to prime it a bit before stepping hard.
    same practice din ang ginagawa ko. mga 500 meters ata before mag auto-switch to lpg pag naabot na desired temp. every weekend gas mode. karga gasoline 500 every 2-3weeks.
    that's my initial thought din na baka effect lang ng drive by wire but comparing it side by side with gasoline parang hindi lang siya sa drive by wire e. pag naka lpg ako kasi, pag pinitik ko yun accelerator from stand still, yun tunog ng makina ay parang hangin yun pumapasok (hindi ko lang alam kung ano technical term nito). pag naka engage yun gear like first gear from stand still parang maramdaman mo na magshake unti engine pati yun stick shift pipitik siya. paghindi mo nacontrol gaano yun clutch possible mamatay makina. kaya hindi ko siya pinipitik or biglang tapak even parang ganon naman nakasanayan natin both sa gasoline and sa diesel. phasing na tapak lang ginagawa ko na.
    nashare ko lang ito at baka naexperience na din ng mga naka lpg at makapagbigay ng tip kung paano naayos. kung hindi maayos ok na din naman sakin since satisfied na din naman ako sa kit ko both power and economy.
    thank you again.
    #3825
    Hi guys! would like to update everyone on the price increase of Auto LPG effective today. Pump price is at 34.90 on most stations. Winter time in EU drives up the world price.
    #3826
    Quote Originally Posted by XOOMaster View Post
    Sigh. I miss the P18.00/L days.
    May 2010
    #3827
    sana maabutan ko pa yun 31.40 sa Total station sa may pasay mamaya
    #3828
    I just had filled up my LPG tank. I also miss those sub-P20/L LPG days.
    May 2008
    #3829
    Quote Originally Posted by paolorenzo View Post
    Next project is to get my Revo's gas tank and fuel lines cleaned up, and fuel filter replaced. I went back to gas for a whole week while LPG was dead, and I could feel na parang sakal yung gas. Meron lag. Feeling drive by wire ang Revo ko.
    Where did you have your fuel lines cleaned? Did they flush out the gas lines with a solvent? My car runs great on lpg but can't seem to keep the engine running when on gas. I already replace the fuel pump, fuel filter and distributor, cleaned the intake manifold, changed the spark plugs but the problem still persists. Parang nalulunod pag gas gamit ko hanggang mamamatay nalang yung makina. I was thinking baka yung fuel lines nagbara na din.
    #3830
    Quote Originally Posted by eikichi View Post
    How old is your gasoline? And what gasoline do you have in your tank? (Shell Unleaded? Caltex Silver?, etc)
    May 2008
    #3831
    My gas normally lasts for about 1-2 months between refills of P500. I usually put Shell Premium. I'm really having a hard time with my engine. A mechanic told me recently that this is because of the LPG that destroys the pistons. I'm not sure if he's just discouraging me with my kit or if he's really telling the truth.
    #3832
    In a way he is correct but only IF your LPG kit was set improperly. Taxi drivers somethings adjust the LPG settings to be too-lean, resulting in long term damage to the engine.
    As long as your air-fuel ratio in LPG and gasoline are within the correct range, your engine will do fine.
    BTW, I use either TOTAL PROTEC or PETRON BLAZE in my gas tank. Lasts more than four-five months and still runs smooth.
    #3833
    In my case, my metal fuel line between the tank and engine was clogged almost solid. I had my tank cleaned out but the metal fuel line under the car had to be replaced because the dirt inside has practically solidified. Before it was replaced, my car had a hard time maintaining high revs.
    This could be the same with your car.
    May 2008
    #3834
    This is exactly what I am thinking of. I had almost everything that is gas related checked and replaced worn out parts and still the same behavior. The metal fuel lines underneath may have been clogged for a while so my engine's idle is very erratic. Even a 1500 rpm is difficult to sustain. I tried pressing the gas pedal about halfway and the engine would still have a hard time revving. It would sometimes gradually rev up to 3000-4000 rpm as if getting enough fuel and then slowly go back to its erratic idling.
    #3835
    Sir, how much po ang damage to change the metal fuel line? naka pag palit na rin kasi ako ng filter, cleaned my fuel injectors sa servitek using ultrasonic machine. nag improve ng konti pero at 70++ kph, mararamdaman mo pa rin na hinde smooth ang takbo compared pag naka lpg ako.
    san po kayo nagpagawa at magkano inabot? thanks
    #3836
    Quote Originally Posted by n5110 View Post
    I had it done at Speedlab but I don't remember the costs anymore.
    May 2010
    #3837
    found this site MOUNGMAI RUAMCHANG containing different types of cars converted to lpg with closeup pictures of the installation
    Jun 2008
    #3838
    Hey fellow members,
    where can I find the best LPG kit to install into my suzuki apv??
    Thanks
    *sorry if I posted this in the wrong thread. I dont know where I can post.
    #3839
    Quote Originally Posted by blastme33 View Post
    Hey fellow members,
    Thanks
    Currently I would suggest XOOM Auto-LPG.
    You can find their contact info at the LINK: http://tsikot.com/forums/car-economy...tations-50159/
    Jun 2005
    #3840
    GH, why do you no longer recommend greenfuel? Are they closing shop?
    apart from my not so good experience with a lady from greenfuel and their website is always down i thought they are still a good company
Auto-LPG Conversion Thread
