Page 68 of 211 FirstFirst ... 185864656667686970717278118168 ... LastLast
Results 1,341 to 1,360 of 4201
    Jan 2003
    #1341
    mga bossing,
    going thru the thread, i read that LPG burns cleaner so the car goes thru longer change oils and tune-ups. so can we add this up to the computation for the ROI?
    93 octane has reached 44.20 in my area, one of the lowest i've seen in the metro.... sigh... but with my travel pattern, converting to lpg will take a very long time to ROI since i average 600kms a month only. the only positive thing i see to convert to lpg is environmental.
    #1342
    Quote Originally Posted by bigMIKE View Post
    Lpg cars are very safe. I have been installing and driving one myself. We have installed almost more than a hundred vehicles SGI kits and traditional kits since we started middle of last year. Just know what kind of system they are going to install in your vehicle and follow their maintenance procedures.
    Big Mike,
    Where is your shop? Im interested to know about LPG. Im into different fuel systems/alternative fuels. We met in Clark last Saturday.
    #1343
    Quote Originally Posted by 4JGtootsie View Post
    Big Mike,
    You can contact Mike at his office numbers.
    Tel: 895-9540; 895-6587; 729-9075
    #1344
    *meledson & *enzo18
    The problem with SGI LPG kits is that the kit is expensive hence the longer ROI period.
    The better alternative is the closed loops system currently offered by DENSO/COOLMATE Corp.
    As mentioned by Mike, his kits are priced at P24,000 to P25,000 depending if your car is equipped with oxygen sensors. (If your car has a factory oxygen sensor, the LPG kit will be priced at P24K).
    This closed loop LPG kit offers the user with a more balanced air/fuel system (as compared against "traditional" open loop systems) with the low and more affordable installation price. The only other type available to offer balanced air/fuel systems is the SGI kits which are (obviously) more expensive.
    So for those who are disheartened about buying a SGI-LPG kit for their car, I strongly suggest to look up the closed loops system being sold by DENSO.
    #1345
    Quote Originally Posted by impulzz View Post
    mga bossing,
    true, we can add that to the computation but I still prefer keeping my regular oil change/tune up schedules as a preventive measure.
    If you are aiming for a SGI kit, true it will take a very long time. But if you get a cheaper closed loop kit, it would just take half the time to reach ROI.
    #1346
    We have a promo from now to this coming April for Euro-certified SGI kits 4 cylinders. Promo is for first 100 kits only
    For all Toyota Altis, Avanza, Vios, Camry, Fortuner and Nissan Sentra GX model, Nissan X-trail, Honda CRV, Honda Civic and Honda Accord (late Model)
    Avail of our SGI kits for only Php38,000 40L tank inclusive
    Hope to hear from you guys soon
    Aug 2005
    #1347
    *meledson & *enzo18
    For now, di pa viable na mag LPG ako sa Avanza. Ma void ang warranty ng engine pag pinagawa ko ang upgrade to LPG sa labas ng casa. I do not have the exact details, pero I am assuming na puwede sa casa kaso napakamahal naman.
    Mayroon akong gasoline allowance sa caltex. ewan kung puwede sa autoLPG.
    Jan 2008
    #1348
    sir GH, anyone,
    i've gone through the whole thread kaya lang di ko na ulit makita yung tungkol sa closed loop. may i ask if:
    1. closed loop kit won't need adjustment on the 'degrees' of timing, calculated na yung lpg/air mixture?
    2. pag umakyat ng baguio o tagaytay kahit all the way LPG ok lang?
    Jan 2003
    #1349
    sir is this number for Mike of Denso or Bigmike of tsikot? or are they the same person?
    #1350
    Mike of Denso.
    The auto-LPG Mikes:
    Denso = Mike Tagle
    Greengas = Mike Lim
    #1351
    Quote Originally Posted by enzo18 View Post
    sir GH, anyone,
    Well, actually depends. Generally you don't need to adjust the ignition timing but to get better performance under LPG, you would still need to adjust the ignition timing. You engine will run fine with gasoline and LPG with factory stock timing.
    I have driven my LPG fueled corolla a/t all the way to baguio. My only problem was when I got to Baguio, the engine was running a bit rough since I needed to re-adjust my fuel flow to compensate for the thinner air in Baguio (it was running a rich mixture). Since I was only staying in Baguio overnight, I decided just to switch over to gasoline while in Baguio City.
    Jan 2008
    #1352
    another Q sir GH,
    while in baguio (and the air is thinner), ok lang gamitin ang LPG kung naka closed loop system na? meaning hindi na magiging rough ang takbo ng engine dahil sa closed loop?
    #1353
    another Q sir GH,
    The closed loop LPG kit will adjust the flow of LPG to balance the a/f ratio if you drive to Baguio. So the result will be a smooth running engine without manually adjusting it.
    Aug 2007
    #1354
    Mike
    My shop is in Mandaluyong. My contact details are at 09228231270 or land line 9942248
    My company is GREENFUEL SYSTEMS AND TECHNOLOGY INC you can visit my website at www.greenfuel.com.ph
    Hope to hear from you guys regarding your inquiries
    Hey Mike,
    I remember you. Since when did you have these new systems? Anong brand na ang dinadala mo? I remember you had Ultragas before eh. Do you still carry that line?
    Jan 2008
    #1355
    may nag avail na ba sa ALPGAS? may deferred sila, 12mos at 0% interest.
    http://tsikot.yehey.com/classifieds/...t/19408/cat/11
    #1356
    Thank You Sir Ghosthunter!
    big Mike try to pass by later. Salamat.
    #1357
    Quote Originally Posted by webmiester View Post
    Mike
    Hey Mike,
    We still carry ultragas. Greenfuel is the local distributor of ultragas.
    Pardon my memory where did we meet?
    #1358
    4JGTootsie
    Feel free to drop by. If you can't find our garage give me a call
    webmeister
    We still carry ultragas. Pardon my memory where did we meet?
    #1359
    I just had a chat with Mike (Greenfuel) & his partner Warren.
    They are offering open loop & SGI LPG kits for a rather good price.
    Standard SGI kits would start at P39,000.
    Open loop LPG kits at P18,000.
    Open loop w/ EFI emulator LPG kits at P20,000
    [SIZE="2"]Note: cars with plastic engine intake manifolds must use the SGI kit[/SIZE]
    The standard kits come with a 40L tank. Bigger and donut tanks are available as options for a relatively small additional charge.
    Their kits are based around Italian & Turkish LPG parts.
    The SGI kits are fully automatic. It would start in gasoline then shift to LPG after a few seconds. If you run out of LPG, the vehicle with automatically shift back to gasoline. This kit from Greenfuel supposed to have a "lubrication" cycle where every 15 minutes of operation, the system will inject gasoline for a few seconds. This would help keep the gasoline fuel system in working order.
    They showed me their Nissan X-Trail fitted with the auto-LPG SGI kit. The donut tank is where the spare tire used to be, so you will still have the same storage space are the rear. The engine-bay side conversion looks clean except the wiring might need something better than electrical tape, maybe some proper wiring wrap but otherwise it looks well done. The electronic control box is located under the dash so it won't be exposed to the heat in the engine bay. Starting the engine, the LED based indicator said the system was running on gasoline, after a short while, the four GREEN LEDs lit up indicating LPG operation and the relative content of the LPG tank as well.
    Overall, the Greenfuel LPG kit seems to be a good deal in terms of affordability and quality of installation.
    You can contact them:
    Greenfuel Corporation
    Michael Lim
    telefax: 725-6731
    mobile: 0922-823-1270
    info*greenfuel.com.ph
    #1360
    Hi Guys
    In case you haven't heard. Price of gasoline went up Php0.50/liter today and price of auto-lpg will be rolled back Php0.50/liter.
    There is no better time to install an auto lpg system than now. With the pending series of increases in gasoline prices towards the US summer driving season your savings on running your engine on auto-lpg will be bigger and your recovery period for your auto-lpg kits faster. This kit actually pays for itself over time. The sooner you convert the sooner your savings start
    Have a good day
Auto-LPG Conversion Thread
