Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 105
    Aug 2004
    #81
    Yup... should turn off the aircon... when you run through a flood that deep, the bottom of your engine is already underwater... and your accessory belts are underwater, as well.
    When the aircon loses its cool... that means the belt on the AC compressor is slipping because it's wet... you should turn it off to prevent damage due to this slippage.
    Jan 2009
    #82
    *projector
    +1000000
    Ok yun pag extreme emergency. Dapat may baong extra washing machine tubes at duct tape (pwede dikit kahit basa at umuulan).
    Nakalimutan lang sa video yung air intake pa engine. I'd open the hood, plug a tube there and tape it high so no water gets in there. Medyo iba kung CAI nga lang.
    Pang emergency yung ginawa.
    #83
    [SIZE="4"]Best vehicles for floods:[/SIZE]
    J. Clarkson's Nissank:
    J. Clarkson's Toybota:
    Jun 2009
    #84
    :lolabove: ^ originally posted at TGP_Forum.
    [SIZE=1]ano kaya mas bagay, codenames "kariton" or "tadpole"..(joke) :peace:[/SIZE]
    Jan 2011
    #85
    my snorkel ba for sedans?
    #86
    Quote Originally Posted by timrev View Post
    No but you can retrofit the ones from SUVs and pickups to sedans... but given most sedans are gasoline fed, it would be pointless.
    Aug 2011
    #87
    Another tip.
    Keep your left foot off the clutch as much as possible. Maski nakalubog ang muffler mo your engine will not stall.
    Aug 2004
    #88
    A gasoline car will run until the water seeps past the spark plug boots and causes cross-firing... Which would take a few minutes. If you vae a snorkel and the ECU is protected, you can make short crossings.
    #89
    #90
    The Hannibal Twin 8 from The Great Race (1965).
    Apr 2011
    #91
    Quote Originally Posted by kersmcrae View Post
    :lolabove: ^ originally posted at tgp_forum.
    [size=1]ano kaya mas bagay, codenames "kariton" or "tadpole"..(joke) :peace:[/size]
    bigfoot )
    #92
    Chitty Chitty Bang Bang (1968).
    Jan 2010
    #93
    I once saw a 2001 Lancer ford a flood up to its headlights in V. Luna.
    A couple of SUV's followed and didn't make it.
    Jul 2006
    #94
    Eto ang gusto ko he he he...
    Mar 2004
    #95
    Either the driver of the Lancer was not the owner or you can imagine the headaches in maintenance he got a few months after fording the flood.
    Jan 2011
    #96
    ot: makikisabit
    ask ko lang kung panu makakaiwas makabili ng 2nd hand car na binaha?
    Aug 2004
    #97
    ot: makikisabit
    Typically, look for signs of mud or water stains in hard-to-reach and hard-to-clean places. No other method is surer.
    Aug 2004
    #98
    Perfect 'to for Manila. Heated spike for jaywalkers. Raised for floods. Cannon for buses. Smokescreen for ASBU. Twin engine nga lang. Aircon na lang kulang
    #99
    L300 Versa Van - another ancient diesel w/o ECU (good for the floods)
    i used l300 gas in knee-deep pasong tamo flood with no problem. also did knee-deep with liteace 5k gas before with no problem. both are cheap and easy to maintain, and there's plenty of space at the back in case you get stranded.
    Aug 2004
    #100
    Quote Originally Posted by onewaytrip View Post
    Knee-deep is nothing to most cars. The problem with the L300 is the air intake is under your butt. Once you hit waist-deep water, you're sunk.
Which one would be best driving thru floods?
