Results 1,561 to 1,570 of 1594
March 10th, 2024 07:17 PM #1561
Finally, an 8AT GR Yaris/Corolla...the Lexus LBX MorizoRR
https://youtu.be/9ugc1ZMm5qs?si=bNCdUtO8p0BdmZq6
March 11th, 2024 10:59 AM #1562
I'm just glad I'm of the generation that grew up learning to drive on an M/T. And even though I have since been driving an A/T in the last couple of decades, I can still drive any M/T vehicle (car or bike) like a pro.
That clutch muscle memory just stays with you forever.
March 11th, 2024 12:35 PM #1563
I learned something new last saturday when climbing uphill.... While depressing the brake and clutch, you slowly let go of the clutch while brake is still depress. Then if you felt the engine is shaking you quickly shift your right leg to the gas pedal and your vehicle will not move backward. This is something new as I was thought before to quickly shift to clutch and gas pedal climbing uphill so my vehicle would move backwards a bit.
- Mar 2008
- 54,206
March 11th, 2024 12:41 PM #1564
March 11th, 2024 12:53 PM #1565
- Mar 2008
- 54,206
March 11th, 2024 02:02 PM #1566you can feel if the vehicle will or will not be able to do the uphill climb.
if it can, then i don't shift down anymore.
if it can't, then i shift to lower gear and higher gas.
i do not think of the other vehicles which might think i am going too slow.
the left lane is wide open for overtakers.
March 11th, 2024 02:43 PM #1567
- Mar 2008
- 54,206
March 11th, 2024 02:59 PM #1568coming from a full stop, going up the hill,
is just like starting to move the car from a full stop.
step on clutch (and brake, if you feel so), and put it in primera.
then step on the gas as you simultaneously slowly release the clutch. this is crucial, because if you don't mix it right, either your car will stall, or your car will shoot forward fast.
and up we go!
along the way, if you feel you can shift to segunda, do so. your car will complain if this is a wrong decision, naman.
March 11th, 2024 03:29 PM #1569
Tsikot Member Rank 2
- Jan 2007
- 2,587
March 11th, 2024 04:44 PM #1570
Because pinoy mentality. Not surprising.
Mitsubishi Montero Sudden Acceleration Accidents...
