Results 1 to 20 of 1594
    Jun 2008
    ^Haha! No worn-out clutches...maybe PUJs should have A/Ts. They ruin their clutches all the time!
  2. #2
    robert--kung AT mga dyips, mag-mumura naman ang operators sa costs of repairs...
    kaya nga wala nang AT na taxi...
    Jun 2008
    Ah...I get it! Hehehe...drivers can't drive.
    True, it's harder to destroy an A/T than an M/T. Unless you use "D" all the time on steep inclines. My old car has 244TKm on it and still doesn't need an A/T repair kit. I just have the ATF replaced and the filter cleaned every 40TKm.
    Dec 2007
    There's nothing wrong with using D on steep inclines, as long as the tranny doesn't go gear hunting back and forth.
    Well, at least for modern A/T's...
    Quote Originally Posted by woohoo View Post
    Sir my cousin recently burned his Starex's A/T while in "D" going up Quezon province national park. What you say is true but you still have to be sure the tranny is in the right gear (RPMs not so low) to make sure the clutches aren't partially engaged for long. It's hard to tell if you are in the right gear if you are just in "D".
    But I agree with you that using "D" will not damage your tranny if you are conscious of what gear it's in.
    Dec 2007
    Right, but if you observe your car and remember at what RPM and speed it switches when:
    1. accelerating slowly
    2. accelerating very fast
    3. accelerating moderately fast
    then you won't have difficulty figuring that out. Experience is the best teacher, isn't it?
    Sa manual naman ng Toyota vehicles, laging nandun yung "Do not continue to climb uphill in 2 or L, to prevent your transmission from overheating." (I paraphrased). Seems inconsistent with what happened to your cousin's Starex.
    Sir woohoo I know that. Just wanted to post for the newbies. I find that entry in the Toyota manual odd. My Innova's clutch started to smell at 3rd gear while going up at about a 45% incline. The next time I went to the same place I slowed down and stayed in 2nd. The smell was gone.
    *oj88
    The Starex had 20Tkm on it, spent mostly on long drives in the South. Granted they were 80Kg each and there were 7 of them, hehe. If you use your a/t properly I don't think it should conk out that early. My oldest car has 240TKm on it and it still shifts smoothly.
    Jan 2009
    *oj88
    I agree. Something went definitely wrong in that A/T. Anyway, warranty should cover it.
    Jan 2009
    Without knowing the actual condition of his A/T, we can never really say that going uphill destroyed his A/T. Yes, going uphill will heat up the A/T, but these things are designed already with that in mind. It may just be possible that your cousin's Starex have an already-dying A/T... it just took one more uphill trip to finally put it to rest.
    "D" is usually sufficient for most driving conditions. It should be able to handle occasional uphill and downhill grades with ease. There are situations however, that you need to intervene, hence, the lower gears are provided. Additionally, the Starex I believe has three A/T modes; normal, power, and lock (cmiiw). Then there's also the option to turn on/off the OD gear. That said, the driver should know how to use these settings properly depending on the road condition. The normal "D" can only do so much. Misuse of these settings can potentially destroy your A/T.
    Modern A/Ts have gone away with the different modes mentioned above to take the driver's decision about which one to use out of the equation. Instead, the system relies on a bit of AI and fuzzy logic to determine the proper gear/mode to use for a given situation. However, the lower gears are usually still available in case the driver senses a need for them.
Battle of the Transmissions: M/T vs. A/T
