Results 191 to 200 of 1594
- Feb 2004
- 138
February 26th, 2009 08:25 AM #191How about maintainance and repair cost of MT vs AT? Di ba super mahal pag nasiraan ka ng A/T?
February 26th, 2009 04:15 PM #192
maintenance - mura ang AT(atf flushing lang yan every year or 2).. mag-mumura ka sa MT (clutch disc,pressure plate,release bearing, clutch primary&secondary master repair kit, hoses, labor pa pagbaba..damay mo na din ang crakshaft oil seal sa checking...)
repair cost - mag-mumura ka sa AT(either palit ka ng un-certain-used AT, or spend 100t minimum on overhaul, na di din sigurado ang gawa)...mura MT (pag nag-slide, un ang maintenance, pag pinabayaan mo, chances are machineshop mo ang housing/flywheel)
ganun lang yun..so pag AT ka, better ang maintenance..problema lang if you bought the car "used"
February 26th, 2009 05:24 PM #193
for me M/T kasi i'm located in a province and the road here are 2 lanes only bihira ka lang makakita nang 4 lanes kung malapit ka na lang sa city and its really hard to overtake pag A/T gamit ko kasi ang tagal bago mag accelerate need to rev high pa unlike sa M/T control ko yung power nang sasakyan at acceleration nya..pero if sa city driving na mas prefer ko A/T's...
February 26th, 2009 06:32 PM #194
most at are high-geared.. ang mt naman ay low-geared..
but siyempre, take into consideration pa yung huge losses ng AT because Fluid is the main medium..torque converter...
e ang MT directed halos sa shaft/flywheel..kaya mas lesser ang powerloss.
and maybe your AT car is not built for speed or di kaya may issues kaya di ganun ang acceleration.. e bakit yung kia pride ng mom ko, during its prime, its so easy to overtake, despite the 1.3L and 3-speed AT.. its in the technique na din.
March 3rd, 2009 10:40 AM #195
sir AY dito kasi sa province in terms of overtaking not only mid size ang ini overtake mo consider po yung mga prime movers na nagka ka sunod sunod need power and fast acceleration talaga..ok lng po sana kung yung mga latest tranny cars na kasi easy na lang mag pick up nang speed..
- Sep 2007
- 174
March 10th, 2009 09:11 PM #196overtaking sa AT? madali naman sa Honda City '03 IDSI. Iset mo lang sa S mode and shifter ayun para kang naka turbo! lakas lang sa gaso....
April 9th, 2009 08:28 AM #197
Ganun ba yun? overtake ako ng overtake sa Honda City 1.5 VTEC nasa D lang naman. yun nga lang pag ganito gawain ko lagi sayang sa gas. sa CVT gearless kaya wala low gear hi gear issue. Unless shift mo sa manual mode para meron ka 1 to 7 gears (di ko din ginagawa).
- Jan 2007
- 14
April 9th, 2009 09:53 PM #198sticky thread na pala to... It's been 3 years na since i posted this. Ngbibida kasi ung kasama ko noon na maganda ang A/T kesa sa M/T, samantalang kakastart pa lang nyang magdrive at matutong umapak sa gas. hehe. Nice to know dami ngshashare ng ideas dito, that's the spirit mga repa! i had my car traded in to a new one. i stuck to M/T pa rin. hehe. i'm open to ideas having A/T though.
Very informative... keep it coming mga repa!
April 10th, 2009 10:29 AM #199
A few more things I can say.
The automatic transmission has come a long way in terms of reliability and efficiency. Modern A/T's are more intelligent, more fuel-efficient, and sometimes integrates a lot of features previously only available to luxury cars.
It used to be that the only compelling reason to buy an A/T car is convenience, and that the price you pay is bad fuel economy. Now, fuel-efficiency on A/T's has become at par or to some extent, even better than M/T under certain situations. It'll be unfair to compare the modern A/T to the those models from the 70's-80's or even the 90's. So if the last time you drove an A/T was way back in 1989, you can't use your judgment back then and apply it to modern A/T's. If you need to decide, you should always test drive both M/T and A/T models of the car your'e interested in.
April 10th, 2009 10:41 AM #200
Pag naging mainstream na ang Dual-clutch systems, lalong lalamang ang mga AT
Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage Jay...
2023 Toyota GR Corolla Hatchback
