Results 171 to 180 of 1594
November 29th, 2008 04:25 PM #172
oliver - i think the marketdictated that. kaya most matics are on the top-level trim, mga manual restricted to the base model..
deym!
kaya no choice.. kung sana nga pwede kang mamili before you buy--parang burgers-- ung prenuim ginagawa lang upon order.
pero cost-cutting din kasi,e...
me want the options of the exalta granduer/STA but sadly matic lang siya available...
and the g.livinia MT is semi-stripped down.. the lux ver is only avail in AT..
yung innova V, matic lang din.. but nga yung AT na avanza trip meter lang difference sa 1.5MT.
swift na AT at MT identical sa equipment.
November 30th, 2008 10:37 AM #173
i used to drive m/ts. i had misconceptions then about a/ts being slow, gas guzzler and not so powerful.
then i purchased a sorento a/t and my eyes were opened to the convenience, comfort and driving pleasure using a/ts. the sorento is such a pleasure to drive that i sometimes i dont use my driver anymore even for long trips. now, i will never go back to m/ts.
in fact i recently purchased a strada (gen 2 lang, walang pambili bago) and i opted for a/t. mind you, i do mainly drive my vehicles in the province but still i prefer a/ts.
why? because im just a regular driver, not the racing type, not even the offroader type.
as for the fuel consumption, i suspect i even made better fuel consumption with a/t because i usually lift off my foot when driving to take advantage of the free wheeling mode of a/ts when coasting.
just my 02 cents and change
November 30th, 2008 12:05 PM #174
Ilagay mo sa L then apply a little pressure sa brake.
pag bigla ka naman hiuminto sa gitna ng baha, ilagay mo kaagad sa neutral then rev the engine pero its a myth.
hindi naman papasok ang tubig sa exhaust as long as umaandar ang engine.
check your brakes lang pagka ahon sa baha,
November 30th, 2008 12:18 PM #175
my observation kaya mostly matic ang available, dahil sa haba ng warranty nowadays, minimum na ang 3 yrs or 100K kms at yung iba 5 yrs pa. pag matic no way ma puwersa mo each gear and the whole engine therefore lesser ang potential damage sa engine. 3-5 years time? i don't think bibigay ang matic kung di aabusuhin
hilig pa naman ng pinoy sa modifications. do you think kung may SIR pa na manual ilalaban nila ng 3yrs warranty or 100K kms.?
isa pa mas mahal maintenance ng matic kahit saan tingnan, therefore again mas malaki kikitain ng casaanother is very prone sa damage like baha, wrong gear selection at certain speed etc. esp kung ang ilang new owner ay walang hilig mag-ingat at gamit lang ng gamit. IMO
November 30th, 2008 01:51 PM #176
November 30th, 2008 03:12 PM #177
December 1st, 2008 06:59 PM #178
- Aug 2008
- 172
December 1st, 2008 07:13 PM #179Matic for comfort and long distance. I'm a long time manual driver at nagsawa rin ako kaka-shift.
Try driving in Makati during rush hours for 6 years. That made me choose matic.
December 26th, 2008 02:51 AM #180
I've been driving for 38 years and I drive fast and hard so it will always be M/T for me. The only time I had an A/T was when I had an Accord and it really drove me crazy at times.
I frequently do long trips to remote places so I can't risk an A/T. You are so dependent on your battery and a lot of unexpected things can happen that can drain your battery. Once your battery goes dead and you have an A/T, you're kaput. With an M/T, just push it and ergo, you're on the road again.
In offroading, unless you have traction control, then it's better to use an M/T. Try going down a steep slippery road in A/T and you'll understand what I mean. Step on the brakes just with a little more force than necessary and you'll slide all the way down without any control. Your ABS won't help at all. With an M/T, just put it in 4L-1st gear and you can have a well-controlled descent all the way down without stepping on the brakes. Just taking off your foot from the accelerator will already result to a very, very low crawl that it's almost like stopping without any of the dangers associated with it.
I'm also scouting for my next car and gusto ko naman try hybrid for mother earth. kamusta yung...
BYD Sealion 6 DM-i
