Results 81 to 90 of 139
November 21st, 2002 08:13 PM #81
correct po sir Zhero.....
coolrolla if you plan to use a 10" sub.....better place it in an enclosure to perform well......it is a given fact that small subs function well in enclosures.....while larger subs can manage even without putting it in an enclosure.....and enclosures function on a fixed frequency....pre-tuned kung baga.......so better decide on what subs to use before finalizing your system.....:D
if ever you really need to use the 10" subs.....give me a ring and let's discuss what box we can design for that......:D
- 36
November 22nd, 2002 01:30 AM #82Neilsen,
Since naka-Rockford Fosgate setup ka? ok ba yung RF na Series 1 na 15"? Pano ba ang proper set-up nun? free-air or ported box? Sensya na kung dami tanong... Thanks!
November 22nd, 2002 09:50 AM #83
Rangie it's better to put that baby in a ported box......just like what I did to my series 1 subs.....12" enclosed in a bandpass box.......:D
- 159
November 22nd, 2002 10:54 AM #84Coolrolla,
Try to go to the Dai-1chi showroom in megamall. It will give you an idea of how much those items are... yung extant try calling Ben of Intense sa banawe. If you really want to get a good deal, try going to raon.. they say that the you can get the Fenton/Targa/Dai-1chi products there at 30-50% off from the showroom price!!:idea:
Goodluck!!:mrgreen::mrgreen::mrgreen:
- 115
November 22nd, 2002 10:58 AM #85audio guru's
how about kung fenton na f41000 model (4x1000 ata to)250W per channel....2 channel bridged to power 1 15" na sub..then the 2 chan.to power my boston pro seps...pwede na ba pang spl?
and is it true na pag 1 amp lang to power your system e i init agad yung amp mo?
November 22nd, 2002 01:56 PM #86
a bridged amp powering a 15" sub will do........magiging 3 channel siya......ch 1&2 bridged for the sub and channels 3&4 for the seps.........
regarding naman sa umiinit na amp.......umiinit naman talaga lahat eh.....depende lang sa load na nakakabit sa kaniya.......:D
- 229
November 22nd, 2002 04:00 PM #87Depende rin sa puwesto ng amp. Pag wala gaano ventilation mas mabilis uminit kesa sa may ventilation.
- 159
November 22nd, 2002 05:47 PM #88depende din sa load... if you run the amp at 2ohms pero rated lang sya at 4ohms... iinit yan. also, if you hook up a sub that is way above the max power of the amp, lalo na if the gains are set at full and you play loud. :wink:
November 22nd, 2002 06:31 PM #89
Sirs,
paano po ba mag bridge connection:?::?::?:
yung channel 1 & 2 will combine kaya magiging 1 channel. ch1 + / - where to connect from ch2 + / -:?: is it + to + and - to - or + to - and - to +:?::?:
salamat in advance.:P
November 22nd, 2002 06:43 PM #90
Sirs,
salamat in advance.:P Sirs,
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
