Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 139
    #81
    correct po sir Zhero.....
    coolrolla if you plan to use a 10" sub.....better place it in an enclosure to perform well......it is a given fact that small subs function well in enclosures.....while larger subs can manage even without putting it in an enclosure.....and enclosures function on a fixed frequency....pre-tuned kung baga.......so better decide on what subs to use before finalizing your system.....:D
    if ever you really need to use the 10" subs.....give me a ring and let's discuss what box we can design for that......:D
    #82
    Neilsen,
    Since naka-Rockford Fosgate setup ka? ok ba yung RF na Series 1 na 15"? Pano ba ang proper set-up nun? free-air or ported box? Sensya na kung dami tanong... Thanks!
    #83
    Rangie it's better to put that baby in a ported box......just like what I did to my series 1 subs.....12" enclosed in a bandpass box.......:D
    #84
    Coolrolla,
    Try to go to the Dai-1chi showroom in megamall. It will give you an idea of how much those items are... yung extant try calling Ben of Intense sa banawe. If you really want to get a good deal, try going to raon.. they say that the you can get the Fenton/Targa/Dai-1chi products there at 30-50% off from the showroom price!!:idea:
    Goodluck!!:mrgreen::mrgreen::mrgreen:
    #85
    audio guru's
    how about kung fenton na f41000 model (4x1000 ata to)250W per channel....2 channel bridged to power 1 15" na sub..then the 2 chan.to power my boston pro seps...pwede na ba pang spl?
    and is it true na pag 1 amp lang to power your system e i init agad yung amp mo?
    #86
    a bridged amp powering a 15" sub will do........magiging 3 channel siya......ch 1&2 bridged for the sub and channels 3&4 for the seps.........
    regarding naman sa umiinit na amp.......umiinit naman talaga lahat eh.....depende lang sa load na nakakabit sa kaniya.......:D
    #87
    Depende rin sa puwesto ng amp. Pag wala gaano ventilation mas mabilis uminit kesa sa may ventilation.
    #88
    depende din sa load... if you run the amp at 2ohms pero rated lang sya at 4ohms... iinit yan. also, if you hook up a sub that is way above the max power of the amp, lalo na if the gains are set at full and you play loud. :wink:
    #89
    Sirs,
    paano po ba mag bridge connection:?::?::?:
    yung channel 1 & 2 will combine kaya magiging 1 channel. ch1 + / - where to connect from ch2 + / -:?: is it + to + and - to - or + to - and - to +:?::?:
    salamat in advance.:P
    #90
    Sirs,
    salamat in advance.:P Sirs,
    #91
    Scirocco,
    A little surfing would help...:mrgreen:
    Anyway, mahirap kasi ikwento yan dito... kaya ito nalang...
    Do you see where the sub is connected? The illustration is a 2ch amp. So, if you bridge channels 1&2, that's how it's going to look.
    Goodluck!! :mrgreen: :mrgreen: :mrgreen:
    #92
    8) sound gurus,
    i just purchased a fenton FA41000 (250Wx4) and two 12" phoenix gold QX subs (250W)......my plan is 1&2 channel to power my seps and 3&4 channel to power my subs....balanced na ba tong set up ko? i want spl sana eh...or do i have to power my subs with the fenton alone and buy another amp to power my seps to gain SPL....what can you say about my planned set up? tnx again.....
    :D
    #93
    for more headroom, you can use the fenton for the subs nalang kasi SPL ka naman eh. i think true power rating nyan is around 100-150watts per channel ?
    #94
    Quote Originally Posted by xzrzx
    yep~!!!
    rating is 250watts..
    but the true rating daw is..you can say...mga 100-150... :wink:
    #95
    8) tnx po sa mga replies.,.pano ko ba ma maximize yung performance ng set up ko?....sabi ng iba depende din sa enclosure para gumanda yung bass eh.,...and yung wires....nag aalok yung friend ko...all lightning audio yung wires for 3T ok na ba yon? :roll: :roll:
    #96
    concerning wires........you may use the following.....
    power supply:
    use gauge 10 na stranded automotive wire for your positive line
    you need not spend 3k on wires.......for speaker wires......
    seps:
    any speaker wire will do........make sure that it measures from gauge 18 to 16
    subs:
    use gauge 12 to 10 stranded din......meron sa MG Infinity na earthquake ang brand.......around 65 pesos per meter.......
    ang pinaka mahal na wire sa lahat.........
    signal cable......must be double shielded.......for less noise.......around 800 to 900 pesos depending on the brand.....:D
    #97
    SIR N3IL53N,
    gauge 8 daw yung gagamitin sa system ko...pero tnx sa info regarding sa guages ng wires.....at least pwede kong ipakita sa installer ko what guages he will use.....do you install speakers sir? how about box and wires?....
    :D if you do...can i know your shop land line....
    #98
    wala po akong shop.....pero kami lang ng kapatid ko ang gumawa ng set-up ko sa van......hobby lang namin.....pati sa home theatre systems........gauge 8 will be best for your power supply wire......lalagyan mo ba yan ng distribution block? I also install speakers and make enclosures.........:D
    #99
    Coolrolla,
    Saan ka ba malapit? We can recommend you a trusted shop na malapit sa inyo. :mrgreen:
    #100
    8) sir zhero,
    dito ako pque...may recommendations ba kayo na shop? can i know the no. and sinong hanapin ko don na trust worthy....tnx in advance
    :lol:
car audio set-up
