Cool,
Di kakayanin ng isang 10" ang ganyang bass. I'd suggest at least one 15 inch sub. powered by a very powerful amp.
Cool,
sir Black magic .....chat tayo may tatanon ako sayo....i'll wait for you there tnx
its better if you opt for a bigger sub......let's say 2 15" or 1 18" or 2 12" subs if you really want to go for SPL........:DOriginally Posted by coolrolla
sir neilsen kasi medjo on a tight budget kasi ako eh...so sana may other options.....
What's your car? Corolla po ba?
Kung tight po budget go for Targa subs or the Xtant. Most likely mabibitin ka sa 10" sub. IMO, go for 2 15"ers.
Kung gusto mo talaga yung 10" tapos bayo-bayo, maybe Neilsen or dbaudio can help you design and build a bandpass box/enclosure. It can sound like you have two or more subs. Drawbacks, medyo malaki yung box and it is effective only at a certain frequency range depending on the design and port length(s). :mrgreen::mrgreen:
Paging Neilsen...
dbaudio
09178126620 - look for Dong
sir zhero
tnx for the reply....yup corolla po auto ko.......do you know how much yung targa or xtant na 15"? tnx
how about kung fenton na f41000 model (4x1000 ata to) to power 1 15" na sub...pwede na ba pang spl?[/b]
correct po sir Zhero.....
coolrolla if you plan to use a 10" sub.....better place it in an enclosure to perform well......it is a given fact that small subs function well in enclosures.....while larger subs can manage even without putting it in an enclosure.....and enclosures function on a fixed frequency....pre-tuned kung baga.......so better decide on what subs to use before finalizing your system.....:D
if ever you really need to use the 10" subs.....give me a ring and let's discuss what box we can design for that......:D
Neilsen,
Since naka-Rockford Fosgate setup ka? ok ba yung RF na Series 1 na 15"? Pano ba ang proper set-up nun? free-air or ported box? Sensya na kung dami tanong... Thanks!
Rangie it's better to put that baby in a ported box......just like what I did to my series 1 subs.....12" enclosed in a bandpass box.......:D
Coolrolla,
Try to go to the Dai-1chi showroom in megamall. It will give you an idea of how much those items are... yung extant try calling Ben of Intense sa banawe. If you really want to get a good deal, try going to raon.. they say that the you can get the Fenton/Targa/Dai-1chi products there at 30-50% off from the showroom price!!:idea:
Goodluck!!:mrgreen::mrgreen::mrgreen:
audio guru's
how about kung fenton na f41000 model (4x1000 ata to)250W per channel....2 channel bridged to power 1 15" na sub..then the 2 chan.to power my boston pro seps...pwede na ba pang spl?
and is it true na pag 1 amp lang to power your system e i init agad yung amp mo?
a bridged amp powering a 15" sub will do........magiging 3 channel siya......ch 1&2 bridged for the sub and channels 3&4 for the seps.........
regarding naman sa umiinit na amp.......umiinit naman talaga lahat eh.....depende lang sa load na nakakabit sa kaniya.......:D
Depende rin sa puwesto ng amp. Pag wala gaano ventilation mas mabilis uminit kesa sa may ventilation.
depende din sa load... if you run the amp at 2ohms pero rated lang sya at 4ohms... iinit yan. also, if you hook up a sub that is way above the max power of the amp, lalo na if the gains are set at full and you play loud. :wink:
Sirs,
paano po ba mag bridge connection:?::?::?:
yung channel 1 & 2 will combine kaya magiging 1 channel. ch1 + / - where to connect from ch2 + / -:?: is it + to + and - to - or + to - and - to +:?::?:
salamat in advance.:P
Sirs,
salamat in advance.:P Sirs,
Scirocco,
A little surfing would help...:mrgreen:
Anyway, mahirap kasi ikwento yan dito... kaya ito nalang...
Do you see where the sub is connected? The illustration is a 2ch amp. So, if you bridge channels 1&2, that's how it's going to look.
Goodluck!! :mrgreen: :mrgreen: :mrgreen:
8) sound gurus,
i just purchased a fenton FA41000 (250Wx4) and two 12" phoenix gold QX subs (250W)......my plan is 1&2 channel to power my seps and 3&4 channel to power my subs....balanced na ba tong set up ko? i want spl sana eh...or do i have to power my subs with the fenton alone and buy another amp to power my seps to gain SPL....what can you say about my planned set up? tnx again..... :D
for more headroom, you can use the fenton for the subs nalang kasi SPL ka naman eh. i think true power rating nyan is around 100-150watts per channel ?
yep~!!!Originally Posted by xzrzx
rating is 250watts..
but the true rating daw is..you can say...mga 100-150... :wink:
