Results 91 to 100 of 139
- 159
November 22nd, 2002 08:12 PM #91Scirocco,
A little surfing would help...:mrgreen:
Anyway, mahirap kasi ikwento yan dito... kaya ito nalang...
Do you see where the sub is connected? The illustration is a 2ch amp. So, if you bridge channels 1&2, that's how it's going to look.
Goodluck!! :mrgreen: :mrgreen: :mrgreen:
- 115
November 25th, 2002 08:47 AM #928) sound gurus,
i just purchased a fenton FA41000 (250Wx4) and two 12" phoenix gold QX subs (250W)......my plan is 1&2 channel to power my seps and 3&4 channel to power my subs....balanced na ba tong set up ko? i want spl sana eh...or do i have to power my subs with the fenton alone and buy another amp to power my seps to gain SPL....what can you say about my planned set up? tnx again..... :D
- 40
November 25th, 2002 09:58 AM #93for more headroom, you can use the fenton for the subs nalang kasi SPL ka naman eh. i think true power rating nyan is around 100-150watts per channel ?
November 25th, 2002 11:51 AM #94
Originally Posted by xzrzx
rating is 250watts..
but the true rating daw is..you can say...mga 100-150... :wink:
- 115
November 25th, 2002 12:49 PM #958) tnx po sa mga replies.,.pano ko ba ma maximize yung performance ng set up ko?....sabi ng iba depende din sa enclosure para gumanda yung bass eh.,...and yung wires....nag aalok yung friend ko...all lightning audio yung wires for 3T ok na ba yon? :roll: :roll:
November 25th, 2002 03:12 PM #96
concerning wires........you may use the following.....
power supply:
use gauge 10 na stranded automotive wire for your positive line
you need not spend 3k on wires.......for speaker wires......
seps:
any speaker wire will do........make sure that it measures from gauge 18 to 16
subs:
use gauge 12 to 10 stranded din......meron sa MG Infinity na earthquake ang brand.......around 65 pesos per meter.......
ang pinaka mahal na wire sa lahat.........
signal cable......must be double shielded.......for less noise.......around 800 to 900 pesos depending on the brand.....:D
- 115
November 25th, 2002 03:59 PM #97SIR N3IL53N,
gauge 8 daw yung gagamitin sa system ko...pero tnx sa info regarding sa guages ng wires.....at least pwede kong ipakita sa installer ko what guages he will use.....do you install speakers sir? how about box and wires?.... :D if you do...can i know your shop land line....
November 25th, 2002 04:05 PM #98
wala po akong shop.....pero kami lang ng kapatid ko ang gumawa ng set-up ko sa van......hobby lang namin.....pati sa home theatre systems........gauge 8 will be best for your power supply wire......lalagyan mo ba yan ng distribution block? I also install speakers and make enclosures.........:D
- 159
November 25th, 2002 05:20 PM #99Coolrolla,
Saan ka ba malapit? We can recommend you a trusted shop na malapit sa inyo. :mrgreen:
- 115
November 26th, 2002 12:41 PM #1008) sir zhero,
dito ako pque...may recommendations ba kayo na shop? can i know the no. and sinong hanapin ko don na trust worthy....tnx in advance :lol:
thanks... this place is more convenient for me.
Recommended Repair Shop - Taguig/Pasig Area
