Page 120 of 154 FirstFirst ... 2070110116117118119120121122123124130 ... LastLast
Results 2,381 to 2,400 of 3070
    Apr 2017
    #2381
    Okay talaga sa mickeys. 3 kami taga LosBanos, Laguna ng mga kaibigan ko, dinadayo talaga namin mickeys. Yung isa Bewith setup, yung isa DLS setup.
    #2382
    Question sa mga audio gurus here. My car is a suzuki jimny. I want to upgrade the stock speakers. 4" speakers and front lang meron. I plan to replace the front speakers and add rear speakers (meron ng wire provision). I have inquired in several audio shops. Laging recommended sa akin is to replace the front speakers to coax speakers daw. Do i really need the tweeters? And gusto nung isang audio shop butasan door cards and doon lagay speakers. Stock location is at the bottom of the dashboard.
    I just want a little better sound that stock.
    Aug 2009
    #2383
    By doing a "feasibility study" on a Jimny before, coax lang pwede. If you want seps medyo kailangan i-sacrifice yung door cards which you've mentioned. If you only want a better than stock sound, pwede na coax upgrade lang. Then kung bitin lagyan nalang ng amplifier below the passenger seat.
    If i were in your shoes, i'm more than willing to sacrifice my door cards para malagyan ng seps. Then kapag bebenta na yung kotse bili nalang ulit ng panibagong door card.
    #2384
    Quote Originally Posted by Sleepcare View Post
    got it sir. pag nag coax speakers na ako, does it mean I need to add rear speakers pa? or no need na?
    as for the amplifier, is it needed if nag upgrade ako to coax na 4 inches parin? most likely hindi ko na bubutasan door cards since this will just be a very basic upgrade lang
    sorry. totally noob when it comes to audio set up
    Aug 2009
    #2385
    It really depends sayo if you'll want to add rear speakers. Please check if same size lang yung coax sa front and provision sa rear. Kung sakto, lipat nalang sa rear yung stock front speakers para hindi sayang and it will act as a "filler" sa cabin ng sound.
    I think that you do not need the amp if that would be the case. Kakayanin naman ng head unit.
    BTW, are you gonna use the stock head unit or papalitan mo din along the way or napalitan mo na?
    #2386
    Naka pioneer na headunit na sir. Sayang nga yung Alpine 117E when i sold my fieldmaster. Hindi ko na naibaklas.
    Same size front and rear. Pwede ko nga lipat nalang yung old stock speakers sa rear, then add front coax.
    Thanks for the advice
    Apr 2017
    #2387
    Any thoughts on "subless" SQ setup? Is it possible with mid level DLS seps and fully deadened front doors? Im using the small pioneer premier 8" shallow sub placed under the driver's seat. Im planning to get rid of it, get a processor and run fully active. Im only using a 4 channel amp and I dont want to buy another amp for the sub. Im using wideband tweeters that can go down to 800-1k hz btw.
    Should I go subless? Or the expenses for another amp+wirings for my sub will be worth it? The sub Im using cant go deep and cant go loud btw, it is too small. And I have no space and no $$$ for shallow, deep, and loud 10inch subs like the JL's.
    EDIT: Current setup is passive. My 4 channel amp powers the seps(with external Xover) and the sub
    Aug 2009
    #2388
    Quote Originally Posted by Lzarellano View Post
    Boss you can try to mount 8-inch shallow mount subs if possible. From there i think pwede ka na mag-dsp. Pero keep that in mind na kailangan mo ng another amplifier+wiring for the sub since channel 1 and 2 takes up the tweeters and channel 3 and 4 takes up the midbass since gusto mo mag-full active. What i've learned from tsikot and other forums is that pwede mo galawin yung HPF and see from there kung makukuntento ka na sa "subless".
    #2389
    magkano ba typical charge sa ganyan bro? labor and material, less sub
    Aug 2009
    #2390
    To be honest, hindi ko alam yung pricing ng shallow mount na sub boxes. But i'll estimate it at around 4k siguro all-in. (not sure if expensive ba kasi never pa ako nagpagawa ng sub box )
    Aug 2010
    #2391
    Is it possible? Of course. Kahit entry-level pa yan. However, the key to achieving a good sub-less setup isn't with fully deadened front doors but by trying to achieve a truly rigid enclosure through the use of many techniques (deadening, inserting foam, etc.) . Hindi lang yan puro deadening (case to point: my doors have like 3 sheets each; still rattles) that's why a lot of people who truly want to go sub-less cut their doors to accommodate a miniature enclosure in it (ex. Bewith midbass). It's like finding a bookshelf speaker and just slapping it sa doors.
    The reason for this is that vibrations is your worst enemy as even a small rattle reduces your decibel output by a lot. That's why a 8" midbass doesn't sound as good as a 8" subwoofer. Drivers-aside, it's usually the enclosure.
    Will it be worth it? Will depend on your taste. My recommendation is to first test it out. I would recommend a 50hz cutoff. Just remember to play around with the EQ and the slopes to get ample low-end. Don't be afraid to pump it up. Most midbass drivers can handle much more than you think.
    Aug 2010
    #2392
    And you'd be surprised how creative people can be in making subwoofers. For example, I really like the recent center mount subwoofer Jonz of Simplesounds made for a client (Simplesound Car Audio - Cainta - Automotive Parts Store | Facebook) Check out that May 23 build log!
    Aug 2010
    #2393
    *crazy
    I would NOT recommend amplifying those 4" speakers as 4" speakers don't really output a lot of bass because of their limitations and many regard 4" to be the realm of "mids" than "bass". You really need the additional wattage on bass producing drivers -- mids and tweets practically sip power lang.
    To be honest, I would recommend a subwoofer to really appreciate a setup using 4" speakers. That way your subwoofer can pick up the bass region. Would I prefer coax? Nope. I'd still nod in making a 6" hole in your doors to accommodate a separate component than a coax. Fact is: you shouldn't be hearing vocals coming from your hips, dapat ear-level yan dapat.
    Apr 2017
    #2394
    Yes sir naka 8inch shallow ako ngayon. And balak ko alisin kasi ayaw ko sana mag dagdag ng isa pang amp at saka yung wirings pag nag active haha.
    Apr 2017
    #2395
    Quote Originally Posted by jhnkvn View Post
    Thanks sir jhnkvn. Mukhang mas hassle at mas magastos pa pala yung enclosures na ganun kesa mag dagdag ng amp at wirings haha pero gusto ko yung ganun, interesado ako sa ganung setup.
    And dun sa box na gawa ng simplesound, parang ganun yung sakin dati before ako mag underseat. Ok talaga sana tas downfire pa, kaso yun nga lang naka buka yung legs ng uupo sa likod haha. Hirap talaga di na ako na contento sa location ng sub hehe, will try sa footwell ng passenger rin. Paglaruan ko muna yung HPF ng seps hehe.
    Aug 2015
    #2396
    hmmmm... naka-buka na tapos nag va-vibrate pa
    Jun 2017
    #2397
    Guys, baka may idea kayo about sa amp na autosonik aa6900, been doing google search, but no idea of the company, reviews of the amp itself. Ano info about the amp, bad or good...TIA
    Sent from my SM-N920C using Tsikot Forums mobile app
    Aug 2012
    #2398
    Quote Originally Posted by signal555 View Post
    Made in Korea according to this:
    AUTOSONIK technology AA69
    Sent from my ASUS_Z010D using Tapatalk
    Apr 2017
    #2399
    Quote Originally Posted by phil15 View Post
    Nakikiliti ng wala sa oras hehe
    Mar 2013
    #2400
    Natawa ako dito. lol
    Pagproblem space but kumpleto ang tunog ang gusto mo, pwede mo try sana 2 6.5" sub ng kicker nasa 3.5k+last ko nakita nakasale sa winterpines dati. Pwede na siya sa ch. 3 and 4 ng amp. Ang enclosure malapad konti sa box ng shoes pwede sa ilalim ng rear seat ng pickup. Gamit ko sa jazz dati ganyan nagsimula sa isa naging 2 6.5" then 1 x 10" DD and now 12" na hehe.
    May 6.5" na DD nasa 2k petot o kaya sundown na 1 lang pwede na din.
audio set-up for beginners [continued]
