Results 1 to 20 of 3070
    Aug 2009
    Quote Originally Posted by Lzarellano View Post
    Any thoughts on "subless" SQ setup? Is it possible with mid level DLS seps and fully deadened front doors? Im using the small pioneer premier 8" shallow sub placed under the driver's seat. Im planning to get rid of it, get a processor and run fully active. Im only using a 4 channel amp and I dont want to buy another amp for the sub. Im using wideband tweeters that can go down to 800-1k hz btw.
    Should I go subless? Or the expenses for another amp+wirings for my sub will be worth it? The sub Im using cant go deep and cant go loud btw, it is too small. And I have no space and no $$$ for shallow, deep, and loud 10inch subs like the JL's.
    EDIT: Current setup is passive. My 4 channel amp powers the seps(with external Xover) and the sub
    Boss you can try to mount 8-inch shallow mount subs if possible. From there i think pwede ka na mag-dsp. Pero keep that in mind na kailangan mo ng another amplifier+wiring for the sub since channel 1 and 2 takes up the tweeters and channel 3 and 4 takes up the midbass since gusto mo mag-full active. What i've learned from tsikot and other forums is that pwede mo galawin yung HPF and see from there kung makukuntento ka na sa "subless".
    Quote Originally Posted by Sleepcare View Post
    magkano ba typical charge sa ganyan bro? labor and material, less sub
    Aug 2009
    To be honest, hindi ko alam yung pricing ng shallow mount na sub boxes. But i'll estimate it at around 4k siguro all-in. (not sure if expensive ba kasi never pa ako nagpagawa ng sub box )
    Apr 2017
    Yes sir naka 8inch shallow ako ngayon. And balak ko alisin kasi ayaw ko sana mag dagdag ng isa pang amp at saka yung wirings pag nag active haha.
audio set-up for beginners [continued]
