Results 2,971 to 2,980 of 3070
- Jan 2018
- 24
March 15th, 2019 06:12 PM #2971
Thats one of the worst placement for a tweeter. You can use the supplied mounting pod of the tweeter and place it on your dash pointing towards the center but if you dont want anything to be placed on your dash, you can mount it at the side mirror for off axis and control it thru eq of your headunit. Tweeters are directional so dont place it where it will reflect on a glass.
I have a new vios and i never placed my teeeters on the stock location.
The best result will almost always be the a pillar and be as much as possible at ear lever. Thats the only speaker in reality you can choose the location where it will have a clear path.
- Jan 2018
- 24
March 15th, 2019 06:21 PM #2972Thats one of the worst placement for a tweeter. You can use the supplied mounting pod of the tweeter and place it on your dash pointing towards the center but if you dont want anything to be placed on your dash, you can mount it at the side mirror for off axis and control it thru eq of your headunit. Tweeters are directional so dont place it where it will reflect on a glass.
- Jan 2018
- 24
March 15th, 2019 06:57 PM #2973
First is download test tones to level properly level the gain of your headunit and amplifier. Set the gain properly for it not to clip. Download a 0db 40hz and 1000hz test tone. Place it on a disc or usb. Remove all eq settings, bass boost and any other enhancement from your radio. At 0 gain from you headunit and subwoofer off, play the 40hz test tone. Place the gain on the amp at 0gain. Up the volume of your headunit slowly until you hear the 1000hz tone. Once the tone you hear gives a different tone that is the max volume of your headunit back it down a few level Until you hear the cleanest tone. Then set your amp gain slowly until the tone you hear produce a different tone, once you reached it back down a bit, thats the max gain of your amplifier. Then go to your subwoofer gain on your amplifier. Play the 40hz tone. Remove first the rca on your speakers. Adjust the gain slowly until you hear a different tone. Back it down until it produces a clean tone. Thats the max gain in your subs amplifier. Now put back the rca of your seperates. Adjust the eq to your liking.
I almost forgot... be sure to check if your speakers are wired correctly. I mean the polarity.
You can watch all of these how to in youtube.
- Feb 2015
- 70
March 17th, 2019 07:41 AM #2974Thanks. Ive used some aluminum tweeter pods and mounted it on the a pillar. Height is around 3 inches off the dash. Where should I ideally point them? I've tried playing around but the highs really sounds harsher now haha. Also my car's really cramped everything's blocking the tweeter lol.
- Feb 2015
- 70
March 17th, 2019 07:45 AM #2975
- Jan 2018
- 24
March 17th, 2019 03:06 PM #2976Try to angle them. Pointing at the center where your dome lights are located. Try to put it as far as you can in your dashboard since its quite tall.
Sound signature ng jbl talaga ang harsh teeeters. theres a switch or botton at the crossover for your tweeters or if not go to your eq and drop the highs until you get the sweet spot.Last edited by Louie47; March 17th, 2019 at 03:21 PM. Reason: Added something
April 6th, 2019 10:15 PM #2977
Hi tsikoteers,
For share lang ng basic sound set-up ko.
Front: DS18 Gen-X 6.5C Seps
Rear: DS18 Gen-X 6.5 Coax
Ampli: Pulse Ryan Audio 4 channel 4.100
Subwoofer: 10" DS18 Gen-X 104D
Ampli: DS18 Mono Amp Candy 1DR
Equalizer: DS18 DS-KEQ7
Question lang po, I'm using stock 2DIN HU (Hyundai Accent), kung magpapalit ng HU mas gaganda pa ang tunog given na may equalizer na ko? Thanks po.
April 8th, 2019 11:03 AM #2978
- Feb 2015
- 70
April 22nd, 2019 09:12 PM #2979Anybody using a DAP as their source? What's a good DAP preferably around 10k. Will hook to a helix dsp. 2. I can't change my HU
April 22nd, 2019 11:09 PM #2980
try Egghead Audiohub, maybe you can find a DAP to match your 10k budget [emoji848]
do you still have hi-res music in storage? i was using a DAP before (a Fiio) but not anymore. i used as source the smartphone now with music streaming Spotify.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
