Results 2,981 to 2,990 of 3070
- Feb 2015
- 70
April 23rd, 2019 10:40 AM #2981
- Mar 2019
- 6
May 12th, 2019 03:22 PM #2982Para saan po ang wire na violet with red stripe sa stock head unit ng innova j? Naka hiwalay sya sa main power harness, sya lang ang nag iisang wire sa 20pin connector
- Sep 2008
- 596
May 21st, 2019 11:34 AM #2983What would be a recommendable single DIN headunit that is in the market? I was hoping to get a wooden finish plate to replace my current one (Blaupunkt) but I doubt if there is still one in the market. I might have to replace my current one as the LCD cannot be read anymore maybe due to old age (it came with the car when bought new).
- Dec 2007
- 186
June 2nd, 2019 11:39 AM #2984i'm also a believer on this and i concur. kahit limited ang budget but you have maximised the potential of the setup, you can still enjoy the sound quality. my advice to aging people and those who have already defeciencies in hearing but would still like the sound of music, have your ears checked by an audiogram to identify which frequencies you can compensate on your setup. kahit anong mahal nag setup but the ears has already problems which has never been identified in what area of the spectrum, is still useless. this i learned from an audiophile friend. and in the modern times, DSp is your friend.
June 2nd, 2019 02:38 PM #2985
for reference,
Single DIN | Product categories | Mickey's Autosound
- Sep 2008
- 596
- Feb 2017
- 141
June 3rd, 2019 12:53 AM #2987Mga boss, kaya ba ng 10th gen na civic yung 2 amp set up (isang mono at 4 channel) na stock alternator lang at walang extra battery? Eto nakalagay ngayon 12" jbl subs powered by gmd9601. JBL seps at stock speakers sa likod. Balak ko lagyan ng gmd9604 para terno sila ng mono amp ko.
Sent from my SM-T705 using Tapatalk
June 3rd, 2019 12:37 PM #2988
June 4th, 2019 07:02 AM #2989
Question lang po, may mahinang white/static noise sa speaker ko. May subs with mono amp po ako at palit ng component at coaxial ang mga speakers with 4channel amp, nakakonek din po sila sa equalizer, tapos stock head unit. Kung magpalit po kaya ako ng 2din na head unit, possible mawala yung noise? Thank you.
June 4th, 2019 11:23 AM #2990
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
