Page 141 of 154 FirstFirst ... 4191131137138139140141142143144145151 ... LastLast
Results 2,801 to 2,820 of 3070
    Oct 2008
    #2801
    X595BT boss. Curious lang kasi ako ano yung readings nya sa time alignment.
    Feb 2018
    #2802
    mga Masters help lang po, meron po akong AVT ISW-1000 active subwoofer meron po syang output wire na blue w/ white stripe na "P Conn" nakalagay, question po saan ko po iyon ikakabit? thanks po mga masters. tsikot ko ay vios 2015
    Nov 2015
    #2803
    Quote Originally Posted by javarya4444 View Post
    remote wire / power connection
    it is the on-off switch for the AVT and controlled by your HU so that the AVT only turns on when your head unit is on.
    Mar 2018
    #2804
    Hi good afternoon. I'm new with audio set up and would like to ask for your opinion as well
    My ride is Ford Everest 2013 model. My audio now is the stock radio i got but since it is busted (gps not working, can't read Itouch, steering controls doesnt function sometimes) I've decided to get Growl audio as my headunit. I have bazooka type nakamichi sub and caido (not sure of the brand) for my speakers and tweeters in front.
    Talked to the local shop and mentioned my plan to upgrade. He said 12k is on a budget meal that composed of Jbl sub (not sure with the model), box, amplifier (kinetic, not sure about the specs).
    Given the budget, do you guys have some specific brand/model in which we can see as alternative?
    Thanks in advance and will wait for your opinon. Have a nice weekend [emoji4]
    Feb 2017
    #2805
    Mga masters, ano feedback nyo sa gmd9601 mono amp ng pioneer? May naka gamit na ba sa inyo? Stock unit lang speakers ko at hu. Nilagyan ko lang ng sub na budget jbl kaso yung amp ko x12 medyo mainit sya feeling ko di kaya eh kaya balak ko palitan.
    Sent from my SM-T705 using Tapatalk
    Aug 2010
    #2806
    Quote Originally Posted by zero3 View Post
    The Pioneer GMD9601 outputs 500/800/1200W and costs $280. If you're talking about price to power, it's sulit naman. Problem is: would you require that much power? Since from the looks of it, chances are you don't need it.
    Your X12 will naturally be hot. As long as it isn't going into thermal protection, ganyan talaga yan. It's a Class AB amp after all. If you're looking for a mono amplifier, it's best to settle for something less pricey. Hindi mo kilangan ng mahal na mono amp as distortion is all but prevalent at the lower frequencies. Kahit PHP9000 Sound Magnus Class D amp is ok na.
    What you'll generally be looking for is:
    - Class D amp - efficiency is king
    - Hopefully it goes down to 1 ohm load - it indicates how good the power supply of the amp
    - Affordability - because everybody wants savings
    Apr 2014
    #2807
    Hi everyone!
    With a Morel Tempo Ultra, is it better to use a Helix G4 amp or Morel’s new amp MPS4.400?
    And do you guys suggest having 2 amps (4 channel + mono amp) or just get a 5 channel amp (Helix G5) instead?
    Thanks in advance!
    bro ask simplesound sa fb, afaik he installed the most g4 and g5s.[emoji848]
    Nov 2015
    #2809
    Quote Originally Posted by babybackrivs View Post
    Hi everyone!
    Thanks in advance!
    Try mo din Sonus
    Oct 2008
    #2810
    My 5mo old X595BT suddenly wouldn't boot. It was working prior to parking then when I am about leave, it did not power on when I started the car. I thought there are busted fuse in my car but testing them yielded good results. I went back to the store and they pulled it out. Good thing I did not sell the stock HU and panels for my vios so I have asked the installer to install it back for the meantime. Hope it gets repaired / replaced soon as I can definitely hear the difference in sound quality.
    Apr 2011
    #2811
    I want to upgrade my civic's (2009 model) speakers. And I want to retain the headunit and just replace the door and rear speakers, are 4 way speakers recommended? And if so what brand to get? Budget speakers only please
    Sent from my SM-A910F using Tapatalk
    Jan 2018
    #2812
    [QUOTE=cmmp;2941952]I want to upgrade my civic's (2009 model) speakers. And I want to retain the headunit and just replace the door and rear speakers, are 4 way speakers recommended? And if so what brand to get? Budget speakers only please
    Sent from my SM-A910F using Tapatalk[/QUOTE
    Jbl or infinity seperates on the front will do of youre in a budget of more or less 3.5k to 5k. Extend it a bit more and get an auditor by focals. For the rear, if you really want to have a rear fill get any of those brand and instead of seperates, get the coaxial variant.
    Mar 2018
    #2813
    For android based hu owners.
    Meron po ba kayong gamit na application as eq? As of current po kase growl audio has only 3. Bass mid and treble.
    Thanks in advance po
    Oct 2008
    #2814
    guys, questions:
    1. ano difference ng "speaker level" vs sa fader settings?
    2. does the speaker level setting affect the time alignment settings? i have the impression kasi dati na ang time alignment, it makes the sound arrive at the same time sa ears natin and I have the impression before na pinapalakas nya yung level ng sound to achieve it.
    Aug 2015
    #2815
    Afaik
    1. Speaker level is the base volume per driver. Fader fades your music to the front, neutral or rear
    2. Your impression is right and it is the fact though speaker level does not affect your time alignment settings it plays a major role in tonality and imaging of your system.
    Quote Originally Posted by artsky View Post
    guys, questions:
    Feb 2017
    #2816
    May kilalaba kayong malupit na audio installer na kayang mapagana yung remote amp ng civic 2017? Yung tamang pag on ng radio, on din yung amp. Ang set up kasi ngayon ay stock h.u. at speakers pero may sub at amp. Yung sub ko at amp may on-off switch para pwede ko patayin ung bass anytime para makapag usap sa kotse.
    Plano ko kasi palitan yung stock speakers sa front at rear at lagyan ng isa pang amp at dun sila ikabit. Bale yung amp ko magiging dalawa, isang sa sub at front at rear speakers. Yung sa front at rear, walang switch remote lang gamit pero yung sub meron. Pwede kaya yun?
    #2817
    front + rear with hi-pass amp - remote powered from HU
    powered sub - manual power switch
    pwedeng-pwede at kayang-kaya iyan kahit hindi malupit na installer. basic lang naman yung remote ON from HU.
    Jun 2016
    #2818
    Im not sure where to post this, so i want first to apologize.
    Possible ba na ma punit yung stock speaker, or even the aftermarket ones, when playing really loud music? T. I. A.
    #2819
    Quote Originally Posted by new_2_cars View Post
    unlikely, but i have seen it happen... in big speakers. not in the small ones used in autos.
    more likely, the speaker is already "previously punited". but that should give itself up as distortion.
    Jun 2016
    #2820
    Thank you sir for the reply. By the way, any recomendations kung anong magandang pamalit for my stock speakers available locally? Something that has a descent sound and bass na plug-n-play. If possible, sana separate yung tweeters. The car is a 2016 Mazda 3.
audio set-up for beginners [continued]
