Page 108 of 154 FirstFirst ... 85898104105106107108109110111112118 ... LastLast
Results 2,141 to 2,160 of 3070
    Aug 2010
    #2141
    Quote Originally Posted by sientobente View Post
    I think the entry level Pioneer X2750BT already has enough tuning options. From Time Alignment, 13-Band Graphic EQ, Active Crossover options. Pioneer also has a higher than usual preout voltage(for future upgrades like an external amp), which is double than Alpine's. Lastly, I prefer the "fat" sounding Pioneer than the clinical Alpine.
    X2850BT na ata yun latest?
    I'm not too sure but I believe 2015's model was a bit problematic according to some installers as the firmware was causing too much RMA's to Pioneer.
    Aug 2010
    #2142
    sold the entire setup, then bought parts for my race gun, bought the utopias at 1k dollars or 24k pesos micky's price, that time it was before erap's presidency, tapos naging president sya, ayun...naging 42k bigla, buti old stock yung kay micky...i used to moderate the AI boards, early 2000s
    Hi bro, this is Andrew's younger brother speaking
    Aug 2010
    #2143
    Car audio in the 2000s versus the 2010s differed not too much naman. I think the primary difference is the shift from analog to digital. For example, AudioControl EQX/etc. were very popular back in the 1990s and the 2000s where time alignment was mimic'ed with the usage of independent L/R EQ and balance adjustment to trick the ears. Nowadays it's all digital -- digital crossovers, time alignment, EQ, etc.
    However, the proliferation of the internet and sites such as DIYMA has largely moved car audio and acoustic theory forward busting a LOT of myths along the way. For example, a 15" subwoofer isn't necessarily faster than a 10" subwoofer -- reproducing a 40hz wave is exactly as it is: back and forth movement of 40 times a second. What is true is that it won't reach higher octaves as the cone is heavier but it exchanges that with a large surface area to push out the low's with authority.
    Kick panels aren't in fashion na either. While they were all the raves before, now it's all about A-pillar installations due to.. well, can't really put up a kick panel if you have a brake pedal there (as in the case of some Hyundai's). They're also a minority too in the United States and people usually do them if they're seeking the pro's of a kick panel install. Otherwise, it's usually the easier A-pillar fabrication.
    Acoustics-wise, same lang. People still attempt to throw flashband sa vehicle floor nila as a cheapo DIY deadening after all.
    What I believe is the challenge is the integration of head units nowadays with processing units. I also believe the future of car audio isn't 2.1 but rather 5.1. Center speakers practically solves the imaging and staging problems of modern cars. That's why they sound incredible. I'm not even tempted to change the HU of the stock 2015 Everest. Maybe the speakers... but not the HU. The "driver" alignment is time alignment in disguise and it implements it really well.
    Jul 2015
    #2144
    Quote Originally Posted by jhnkvn View Post
    man, i know andrew, we used to moderate the AI boards looooong time ago, tinigil yan si andrew sa isang mall, kala bomb yung setup sa likod...pls tell him Neil says hi..
    Jul 2015
    #2145
    there is a big difference...in taste...i mostly listen to AM and podcasts....
    Feb 2009
    #2146
    current CRV model user here. I don't want to lose my steering controls/features. Is installing a DSP the best option for me?
    Aug 2014
    #2147
    Question po. I have a 5 month old 11th Gen Altis. Iniisip ko magpakabit ng Androud HU from GrowlAudio. Mawawala ba warranty pag papapalitan ko yung Head Unit ko? Salamat po.
    #2148
    Quote Originally Posted by ericb View Post
    Your electrical warranty will be voided. But your mechanical warranty should be intact. An aftermarket head unit has nothing to do with a faulty engine. [emoji12]
    Aug 2014
    #2149
    Hi Sir Jut, thanks for the quick response. I asked Growl Sales, they told me that the HU they have for the 11th Gen is connected through a plug and play harness (no idea about this). I'm a little hesitant of upgrading my HU if it will void the electrical warranty, worth it ba yung upgrades kung sakali? Thank you.
    #2150
    For me it's worth it. I also plan on getting Growl HU to have something to amuse me in traffic, once budget permits. [emoji1303]
    There's not much that goes wrong with the Altis' electricals anyway...
    #2151
    Feb 2011
    #2152
    Quote Originally Posted by wakadus View Post
    If you want to upgrade your HU, you need to get a wiring kit to make the MID work. I use Connects2. This brand is widely available in our local car audio shops. It costs around 6 or 7k. There is a cheaper option which is RPac, where you can import it from abroad.
    I'm using an aftermarket HU(Pioneer x8850BT) and an external DSP(Audison Bit Ten) for my 4th-gen CRV. I still like that I can change the settings on the fly through my HU, than pulling out a laptop to setup my DSP.
    Sep 2014
    #2153
    Magkano ang growl HU para sa altis 11th gen?
    Sent from my SM-G920F using Tapatalk
    Feb 2009
    #2154
    thank you! i'll check on that.
    Aug 2010
    #2155
    Electricals rarely conk out. Even then, best have it installed in a reputed installer versus a newbie learning the ropes.
    Oct 2016
    #2156
    mga Boss,
    any suggested sound system setup.
    Budget : <10k
    Amp, subs, speakers ", brands and where to buy in Manila.
    Any suggestion/advise. thanks po sa inyo!
    Dec 2004
    #2157
    Quote Originally Posted by otephz View Post
    mga Boss,
    Budget : <10k
    Try going to Jeff Tan at Araneta car center something. Near sm Sta Mesa lang. He can suggest something good for you
    Feb 2011
    #2158
    mga Boss,
    Budget : <10k
    My advice is to take it step by step. So that through time you can increase your budget. You can change your HU first. Then Speakers. Amp and Deadening. Finally a Sub. If you'd like to take your audio game another level, add a Processor. For that budget, maybe add a little more and get one of those nice 2-DIN Pioneers. They have basic tuning options but are very useful.
    For brands, I'd suggest get one of the established brands so no regrets in the future. Microbrands in my experience has reliability issues. Lately, it's with Flux seps. For some reason, the right tweeter always goes out but cabling is good. Might need to have it replaced. I also didn't appreciate that my speakers went on sale for some reason after acquiring it for just a couple of months. It just proves how cheap Flux is. When I first got it, packaging was basic, and literature is inexistent. It is also even hard to look for specs on these speakers online. What made it worse is the construction of these separates were as simple as Targa components which cost 6x less. It hardly has any branding, and the build looks flimsy. Kinda like generic crap. Next time I'll stick with the tried-and-tested brands like Focal, DLS, Morel, Hertz etc.
    Aug 2010
    #2159
    Didn't know you were disgruntled sa purchase mo Siento!
    #2160
    Sa sound yata satisfied sya bro, i guess sa build quality sya na disappoint.
audio set-up for beginners [continued]
