Results 2,101 to 2,110 of 3070
- Sep 2010
- 3,049
September 29th, 2016 12:05 AM #2101Ended up getting a Pioneer 2850. Got a rear view cam, & connector for the steering wheel as well. Downloaded the pioneer app to connect the phone. Menu seeps a bit complicated. Sometimes, I can make waze to show on the unit, but oftentimes just a blank screen, but there's an audio from waze. Menu seems a bit complicated, maybe just needs some getting used to.
There are some underwear subs that cost around P5k I think.
September 29th, 2016 10:31 AM #2102
^ underwear subs? hindi po kelangan ng bass iyong flatulence ko. malalim na po siya as it is
seriously mga bos, thanks for giving me some idea on the price. will check out shops probably when the rain stops
- Sep 2010
- 3,049
September 29th, 2016 10:39 AM #2103
September 29th, 2016 05:23 PM #2104
- Mar 2013
- 220
September 30th, 2016 03:53 AM #2105[QUOTE=jhnkvn;2770661]Re: Two 8" versus 10"
If your intent is to fill out a City's cabin, even just a single 8" would do the job. You're not into gapang naman (and even if you are, it'll still be enough for the average listener). But to be safe, I'll suggest a single 10".
While two 8" would be theoretically be better, a single 10" would be better for your wallet
Thank you sir jhnkvn!
I end up buying a used RE se12d2 with ported box. Ok naman sya puno ang jazz pagbumira hehe kaso almost puno din cargo area ko hehe. 11x28 ang nasakop. What if i use a rectangular 1cuft sealed enclosure para sa RE? Maganda pa rin kaya? Solved ako sa performance now but masimportante ung space eh. For the meantime inienjoy ko na rin ung medyo gapang na bass haha but i need a mono amp masusunog ung c160 amp ko underpower sir. Planning to buy used sound magus x or vs 1500 pagmaybudget na. Any inputs about this amp? Thanks po again.
October 2nd, 2016 05:01 PM #2106
[QUOTE=joey36b;2771918]T/S parameters of SE and the *** series are the same so you should check that series out for your enclosure recommendations (woofers). The *** is the direct successor of the wildly popular SE-series. I still scratch my head on why you went for a secondhand RE Audio though.. in general I dislike secondhand subwoofer drivers on the basis that most people abuse them heavily
Just get a 1 cu. ft. sealed enclosure. But if possible, stretch it a bit. What you want is to stretch the internal dimensions as much as possible while it's conforming to your size restrictions. For example, if you can still stretch it to a 1.4 cu.ft sealed, go for it.
Reason for this is that a bigger box lessens power handling because box = efficiency. If you needed 500W in a 1.0cu ft box to play a certain sound level, it'll probably need around 300W in a 1.5cu.ft box. I would recommend the best of both worlds, get the ported 1.5cuft box * 35hz. +3dB on the port is not a laughing matter especially if it's +3dB.
- Mar 2013
- 220
October 4th, 2016 11:30 AM #2107[QUOTE=jhnkvn;2772675]My original plan is a pair 8" or a 10" new! until i came across with this for sale RE and ur ideas which i have read in your past post popping in my head hehe
... "why 10" if you could squeeze a 12" and call it a day"
.... about xmax, isip ko 18mm ang RE eto na un hihi
....at 600w rms with 150% w rms mono amp (wala pa ako) will be more head room! Sabi mo nga its better to lower the gain than nothing if you want more...
... from a company who spend more in R&D.
Except used nga lang siya. Tempting eh for a price of 5K with L ported box ( na dinig ko pa kagad hehe. dont know lang wer it tuned). Sumugal na ako hehe. For many times using jumper cable and burning fuels hindi pa naman umusok vc hehe and not even once na distort siya, im aboved average listener.
May konting scratch lang ang cone at medyo gutay ang carpet ng box and i think glue lang katapat. I still prefer na magsealed para space saver.
Na pansin ko lang hindi ako makatagal sa loob ng jazz at high volume masakit sa ulo hehe (magkakahalataan na) haha.
Na absorb ko about power handling so i dont need pla sobra lakas ng amp kung i use ported box.
Sir isang tanong na lang hehe. In box building (sealed) malaking factor ba sa perfornance ng sub ang distance ng rear board sa magnet ng subwoofer? May effect kaya on how low, lapad ng sound ( wat ever), tightness ng bass kung 1" or more ang distance nya sa loob ng box?
Many thanks sir sa mga infos, big help!Last edited by joey36b; October 4th, 2016 at 11:33 AM. Reason: Kulang hehe
October 4th, 2016 05:55 PM #2108
Ok ba ryan audio? Mukhang iyong 8 inchers nila na underseat active sub ang bibilhin ko since pasok sa budget ko
to be or not to be, that always confuses me!
October 4th, 2016 07:45 PM #2109
[QUOTE=joey36b;2773814]1. Yup, a 12" will always be superior to a 8" or a 10" as it can move more air with less cone travel.
2. RE Audio has always been well-loved and well-received
Regarding your question, the answer is.. a simple no. All it cares is the internal space of the box. After all, you can't really know how often will a certain sound wave bounce around inside the enclosure.
For the enclosure, just pay attention to:
1. What material, type, and size of the enclosure.
2. Whether you'll "stuff" it with rockwool or mineral wool inside. Meron effect yan.
3. Its internal bracing. This is how home audio companies sell 6 digit subwoofer enclosures.
4. Orientation. Iba yun sound if you have the speaker fire up or from the side.
5. Where you'll place it in the car.
These are probably the 5 biggest variables on how the subwoofer will sound in your car. #1, #2, and #3 will affect waves of the subwoofer while #4 and #5 is more about acoustics. On a subwoofer basis, #1 is the most important one. But how it'll sound in your car will depend on #4 and #5.
That's why car audio is challenging. Different kasi ang acoustics ng vehicle so even if a certain subwoofer sounds good in Car A, it might not necessarily sound good in Car B if you're hardcore about it
Go mo na yan. Wag na pakipot!
- Jul 2015
- 9,583
October 4th, 2016 08:21 PM #2110
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
