Quote Originally Posted by markygy View Post
Tanong mo sa seller if the more expensive type has a aluminum layer. Yun mga generic type like the acoustipad you mentioned does not have aluminum layer. Mas malinis at mas heat resistant ang mga butyl rubber type deadeing material that has a aluminum layer.
With regards on using the filters on your amp or HU. You neither use one of them since your speakers comes with passive filters already. Just turn off the HPF on the HU and set the the filters of the amp to off or all pass. If the amplifier does not come with the option of setting the filters to off or all pass, leave the settings to HPF.
Yung Acoustipad may variant siya na may aluminum layer and meron yung all black lang na material. I chose yung may alumnum layer and consume 2.5 sheets per door.
Thanks, will try this later. Current setup ko is naka On HPF sa HU front and rear and naka All Pass sa Amplifier. Front seps ko pala is Focal PS 165F and Sound Magus C160 4 channel amp and pioneer coax for the rear.
