Results 1 to 20 of 3070
    Quote Originally Posted by benchman View Post
    depende sir. sedan or van? meron na po ba speakers sa rear kahit stock? kung wala, is it ok for you or the passengers na walang speakers sa rear?
    sedan sir, current set-up ko kasi component at coaxial , yung nababasa ko kasi sa ibang set-up pinapatay/di ginagamit yung rear speaker kapag meron na subwoofer, 4 channel amp ko kasi baka pwede na ikabit ko subs dun sa slot para sa rear ayoko na kasi magdagdag ng 1 pang amp wala na sa budget
    Quote Originally Posted by aprilboyidol View Post
    pwede yan sir. 4 channel amp= 2ch hi-pass front, 2ch low pass in bridge mode for sub(kung supported ng amp mo ang bridge mode and have enough power to drive a decent sub).
    Mar 2005
    Hi, Nag upgrade ako ng stock speakers ng Santa Fe ko. Current HU is Pioneer 2850bt, 4 channel amp, Separates, Coaxials, deadening on all 4 doors and a 12 inch slotport subs.
    Problem ko is nawala yung sound ng mga palo ng drums (midbass?). Yung stock speakers ko meron nun before.. Ano po need i adjust sa amplifier or HU para maibalik yung midbass?
    Gusto ko din po sana na magkaroon ng konting bayo pag inalis ko yung rear subs whenver may karga ako sa rear. Kasi yung stock speakers ko before meron konting bayo so not sure bakit nawala nung nag upgrade ako.
    Aug 2008
    Quote Originally Posted by jmpet626 View Post
    Check your highpass filter sa setting ng h.u. or amp and try to lower its cut-off.
    Apr 2016
    guys saan maganda install ang power amplifier sa pajero intercooler? yung ilalim kasi ng driver and passenger may aircon vent sa ilalim. pag sa ilalim ng 2nd row naman masikip tska may tatamang bakal.
    Apr 2016
    Hi Sir,ask lang po.i have a DLS 426 two way cross and a pioneer ta-a6971e .whats your recommended setup?do i need to buy amp and sub?planning to change my stock ,montero 09.also planning to change hu to pioneer 8850.input greatly appreciated.TIA.
    kailangan parin po ba ng separates kapag maglalagay ka ng midrange/midbass speakers, pwede po ba front and back ng sedan midrange speaker lang ..... salamat
    Aug 2012
    Quote Originally Posted by renzo2003 View Post
    Personal preference ang pag-add ng amp at sub. Depende yan sa objective mo. Bitin ka sa power, add amp. Bitin ka sa bass, add subwoofer.
    Sent from my D5833 using Tapatalk
audio set-up for beginners [continued]
