Results 1 to 20 of 3070
    Aug 2010
    Quote Originally Posted by markygy View Post
    Tanong mo sa seller if the more expensive type has a aluminum layer. Yun mga generic type like the acoustipad you mentioned does not have aluminum layer. Mas malinis at mas heat resistant ang mga butyl rubber type deadeing material that has a aluminum layer.
    With regards on using the filters on your amp or HU. You neither use one of them since your speakers comes with passive filters already. Just turn off the HPF on the HU and set the the filters of the amp to off or all pass. If the amplifier does not come with the option of setting the filters to off or all pass, leave the settings to HPF.
    I'm not too sure about it being more heat resistant. After all, it's not as if you're reflecting the actual rays of the sun when it's inside the door pane and I believe the peeps at DIYMA looks for it more like a marketing gimmick more than anything else.
    However, it does look more clean and if aesthetics is the basis of the purchase I think it warrants the added cost.
    Dec 2007
    [QUOTE=jhnkvn;2725469]I'm not too sure about it being more heat resistant. After all, it's not as if you're reflecting the actual rays of the sun when it's inside the door pane and I believe the peeps at DIYMA looks for it more like a marketing gimmick more than anything else.
    Yes, to be honest I too feel the same way.
audio set-up for beginners [continued]
