ako rin puro double post lately! :|
Sa mga Guro dito hingi po ako ng advice medyo limited lang naman budget ko gusto ko lang clarity. I have new trailblazer kaso ang headunit nya Mylink hindi ko pwede palitan dahil integrated na sa mga function sa vehicle settings.so therefore hindi ako magpapalit ng HU. Eto po yung tanong ko:
1.Kailangan ko bang bumili ng sound processor or Amplifier lang okay na? mahal kasi ang sound processor.
2. anong affordable na separates na okay na ang tunog? may nag suggest sakin DD speaker okay ba yun?
3 Okay ba yung Lightning lab na amp vs V12?
Any suggestion are welcome. Thanks mga bro in advance!
advise needed (again)... i am buying a subwoofer, my amp is rated at 4x100wrms at 4ohm unbridged, 2x200wrms at 4ohm bridged.
setting up seps in front and subs at rear. if i buy a dual voice coil sub, can i connect each coil per each channel? or does the subwoofer need to be connected just to the bridged channel in the amp?
Not unless your amplifier has the option of switching two channels into a mono signal, it would advisable to bridge the connection on the amplifier.
Just remember that if you amplifier is not stable at 2 ohms bridged then you have no choice but getting a dual 2ohm subwoofer. For your reference on how to connect your dual voice coil subwoofer Subwoofer Wiring Diagrams
