*markgy salamat sa reply
ask ko na rin sana kung saan nakakabili ng stereo cable adaptor?
Pang aftermarket head unit ba yan or stock oem? If stock oem, punta ka sa site nang CDR-king to see if available.
I'm looking to replace/upgrade my rear speakers since di na sila tumutunog. Anong size kaya at what components/features should I look for ba? Sorry I'm new to car audio though I'm a longtime member of PDVD and headphiles. The car is a 2008 vios 1.5g. Budget is 7k. BTW I already replaced the HU and front speakers with Kenwood (forgot the model) and focal seperates. I'm also considering adding an amp and sealed sub in the future if my upgrade itch continue hehe.
Hello sir, anu po username niyo sa pdvdI would suggest you skip the rear speakers, para yung staging is in front.
Fentom po sir. I see. So is it ok kung disconnect ko na lang sya?
Could you also suggest an entry level subwoofer setup? My budget is 10k for the sub driver and sealed enclosure ( probably a 10 or 12 incher basta magkasya sa trunk ko) and another 10k for amp, wires caps etc. I'm not really familliar with the brands and models maybe you guys could help me
Get a JBL P1222 (if phased out, its equivalent then) and just throw it at your preferred enclosure (it can do both sealed and ported). For the amplifier, I won't suggest you overpay. A Php5,000 Class D amplifier seems good unless you plan on rocking it out.
Cool! I think 20k for your budget should be more than enough to get you a good subwoofer on a sealed enclosure. I would suggest to probably get atleast a 12 incher. Sir Jhnkvn's suggestion looks like a great option.
