Page 75 of 154 FirstFirst ... 256571727374757677787985125 ... LastLast
Results 1,481 to 1,500 of 3070
    Jun 2013
    #1481
    pasensya po double post, me problem yata pag click ng submit nag eerror tapos pag ok na bigla dalawa na yun post
    #1482
    Quote Originally Posted by Erick Chavez View Post
    sir what do you mean by "Leap in Tonality?
    sorry po medyo slow ako.. :D
    better overall sound quality bro. the same goes with home audio/theater, a properly setup sub can help improve the mids and highs.
    Feb 2011
    #1483
    Since nasa car audio thread tayo, setup na natin yang Swift mo!
    Jun 2013
    #1484
    I see, thanks sir, follow up question lang, you mean bukod sa subwoofer na nasa trunk ay mas ok po ba maglagay pa ng underseat sub?
    meron kasi akong spare na active underseat sub sa bahay kaya naitanong ko lang po...
    Aug 2010
    #1485
    Just use one subwoofer. Contrary to popular opinion, doing two might be more detrimental to your sound quality than just one depending on its placement and settings.
    #1486
    Quote Originally Posted by sientobente View Post
    hahaha walang budget bro, if ever baka drivers lang palitan ko. tangband palang so far naiisip ko kunin bro, pwede kaya yun sa auto?
    Aug 2010
    #1487
    Yes. Hell, I've even recommended them to a person who imported Tangband midranges for use in his car.
    #1488
    Quote Originally Posted by jhnkvn View Post
    hi bro any particular model you can recommend? di ko kasi alam size ng speakers ng swift, standard ba ito or kailangan pa fabricate?
    Feb 2011
    #1489
    Bro, which active underseat subs do you recommend aside from those pricey ones from Focal? Already auditioned some from AVT and Pioneer and they sounded like farts. The audible frequency coming from them messes up the midrange, then when you set it low, you won't hear or feel a thing.
    Aug 2010
    #1490
    AFAIK, Swift uses the industry-standard 6 1/2" mounts. Unfortunately, I'm not much of a fan of Tangband midbass. If you can find yourself some Silver Flutes or Peerless SLS, that'll be great. I'm also quite fond of Dynavox (Dynavox LW6004PMR 6-1/2" Woofer).
    Rather than a normal tweeter, I would recommend you go for the full-range plus midbass combo to save up on fabrication costs. Something like a 2" Vifa (Vifa NE65W-04 2" Full Range Woofer) enclosed in a DIY tennis ball enclosure crossed at 800hz upwards would be great if you plan on mounting it on the dash. Or better yet, throw them on the sails. You want them on-axis as much as possible.
    Now, the next problem will be the head unit.
    I'm not up-to-date regarding active underseat subwoofers. However, I also won't recommend the Focal one. Too pricey for what it's worth - you can only spend so much on physics. Depending on the car, you can probably throw in a slim-mount 10" sealed subwoofer there.
    Why not simply tune your midbass to dig down lower? Most people I know who use a 50hz cutoff on their midbass with a EQ boost on the lower-end tend to be quite satisfied with the music unless you're really expecting the output of a subwoofer. Truth be told, most good midbass drivers can handle quite a bit of excursion.
    Aug 2014
    #1491
    Kapag na rewind na ba yung speaker hindi na nga ba matitino? Masisira rin daw. , . Saan ba may magaling mag rewind yung speaker ko po eh cadence raw driver size 8.
    #1492
    thanks bro, kaso as much as possible gusto ko gamitin yun stock HU nya.
    Feb 2011
    #1493
    Hello friends ako ulit. question lang regarding some Sound stuff , like headunit, what should i look for aside from the USB/Bluetooth etc
    I currently have a budget of 6k and was considering an
    alpine CDE-152E
    features are :
    50W x 4 High Power Amp
    Front AUX
    Front USB
    CD/MP3/WMA Playback
    3 Band Parametric EQ
    High Pass & Low Pass Filters
    3 Preouts Bass Sound Function
    Demo Mode Setting Function
    alpine CDE-152E
    Another thing isa yung amplifier, was considering buying second hand (at 4k budget )na medyo panalo. ano ba dapat titignan ko ?
    higher than this i might consider a bnew like JBL A604.
    may familiar ba sa magnat combat 4000 ? I
    thanks mga sir!
    Feb 2011
    #1494
    double post
    Aug 2010
    #1495
    Sadly, in the state of car audio, it's hard to get the "best" of your equipments with a stock head unit. However, I would recommend that you first install everything first then see if it's to your liking. I know a couple of people who's satisfied enough to use their stock head units after all.
    Quote Originally Posted by kazer View Post
    alpine CDE-152E
    features are :
    Front AUX
    Front USB
    CD/MP3/WMA Playback
    alpine CDE-152E
    thanks mga sir!
    For the head unit, just look for the features. Most of them are really equal in terms of features at any given price point.
    For the amplifier, I suggest upp'ing the budget a bit. A good amplifier will last you quite a long time and if you aren't really in a rush, I suggest purchasing first-hand for warranty purposes. As for the magnat amplifier, nope. I don't know them -- and that kinda means a "don't buy sign" from me.
    Feb 2011
    #1496
    external processor is the way to go idol. lalabas, magiging transport nalang yung HU natin, kasi DAC na ng external processor gagamitin.
    Feb 2011
    #1497
    naisip ko n rin ro up my budget do the amp maybe 10k. 1 time bigtime kumbaga.
    Sep 2011
    #1498
    meron po bang head unit na capable of making a playlist, yung parang sa ipod? I don't know if I sounded stupid with this question, but nonetheless, im asking it he he he
    #1499
    passive ba yan processor bro?
    #1500
audio set-up for beginners [continued]
