pasensya po double post, me problem yata pag click ng submit nag eerror tapos pag ok na bigla dalawa na yun post
Yes. Hell, I've even recommended them to a person who imported Tangband midranges for use in his car.
Bro, which active underseat subs do you recommend aside from those pricey ones from Focal? Already auditioned some from AVT and Pioneer and they sounded like farts. The audible frequency coming from them messes up the midrange, then when you set it low, you won't hear or feel a thing.
AFAIK, Swift uses the industry-standard 6 1/2" mounts. Unfortunately, I'm not much of a fan of Tangband midbass. If you can find yourself some Silver Flutes or Peerless SLS, that'll be great. I'm also quite fond of Dynavox (Dynavox LW6004PMR 6-1/2" Woofer).
Rather than a normal tweeter, I would recommend you go for the full-range plus midbass combo to save up on fabrication costs. Something like a 2" Vifa (Vifa NE65W-04 2" Full Range Woofer) enclosed in a DIY tennis ball enclosure crossed at 800hz upwards would be great if you plan on mounting it on the dash. Or better yet, throw them on the sails. You want them on-axis as much as possible.
Now, the next problem will be the head unit.
I'm not up-to-date regarding active underseat subwoofers. However, I also won't recommend the Focal one. Too pricey for what it's worth - you can only spend so much on physics. Depending on the car, you can probably throw in a slim-mount 10" sealed subwoofer there.
Why not simply tune your midbass to dig down lower? Most people I know who use a 50hz cutoff on their midbass with a EQ boost on the lower-end tend to be quite satisfied with the music unless you're really expecting the output of a subwoofer. Truth be told, most good midbass drivers can handle quite a bit of excursion.
Kapag na rewind na ba yung speaker hindi na nga ba matitino? Masisira rin daw. , . Saan ba may magaling mag rewind yung speaker ko po eh cadence raw driver size 8.
Hello friends ako ulit. question lang regarding some Sound stuff , like headunit, what should i look for aside from the USB/Bluetooth etc
I currently have a budget of 6k and was considering an
alpine CDE-152E
features are :
50W x 4 High Power Amp
Front AUX
Front USB
CD/MP3/WMA Playback
3 Band Parametric EQ
High Pass & Low Pass Filters
3 Preouts Bass Sound Function
Demo Mode Setting Function
alpine CDE-152E
Another thing isa yung amplifier, was considering buying second hand (at 4k budget )na medyo panalo. ano ba dapat titignan ko ?
higher than this i might consider a bnew like JBL A604.
may familiar ba sa magnat combat 4000 ? I
thanks mga sir!
Sadly, in the state of car audio, it's hard to get the "best" of your equipments with a stock head unit. However, I would recommend that you first install everything first then see if it's to your liking. I know a couple of people who's satisfied enough to use their stock head units after all.
For the head unit, just look for the features. Most of them are really equal in terms of features at any given price point.
For the amplifier, I suggest upp'ing the budget a bit. A good amplifier will last you quite a long time and if you aren't really in a rush, I suggest purchasing first-hand for warranty purposes. As for the magnat amplifier, nope. I don't know them -- and that kinda means a "don't buy sign" from me.
naisip ko n rin ro up my budget do the amp maybe 10k. 1 time bigtime kumbaga.
meron po bang head unit na capable of making a playlist, yung parang sa ipod? I don't know if I sounded stupid with this question, but nonetheless, im asking it he he he
