Results 241 to 250 of 3070
- May 2008
- 9
July 4th, 2011 07:34 AM #241sir so better invest muna ako sa magandang HU? anu po ba ang bang for the buck na HU sa market ngaun
- Mar 2009
- 71
July 5th, 2011 10:52 PM #242mga sir ok na ba kung lalagyan ko ng amplifier yung stock speakers or magiging useless lang, kailangan ba palitan din ng separates yung stock speaker ayoko naman lagyan ng subwoofer gusto ko lang po kahit mataas ang volume maganda padin tunog hinde basag, meron po ako sony 600 watts amplifier at extra pair ng sony 6.5 coaxial ...... salamat
July 6th, 2011 10:31 PM #243
Stock speaker po is design only on the stock head unit power, so if you add only amplifier, you will powering those speakers, then the result is mas ok ang tunog nun kesa dati, problema, limitado pa rin po yung stock speaker * certain frequency response since it built only to sound as stock. Meron po akong ginawa na ganyan, toyota innova, nagpalit ng head unit na pioneer, then meron din sya isang amp(4channel) at isang sub, so ang ginawa ko, inamplify ko yung harap na speaker para naman umangat konti yung mid range nya and yung sub, set ko yung cut off frequency sa 80hz ng head unit para sa front speaker, ayun, di na basag, distortion lang talaga if you turn the volume up to 2/3 ng head unit. Mas maganda, palitan mo na din yung stock speaker for at least 50watts rms or kung anu bagay sa amp mo, sayang ang power e, Morel Maximo seps, kung naghahanap ka ng malinaw na mura, tested na to simula pa e, kahit wala kang sub ok na, i installed it on monterosport 2011 last monday, the best, kasabay ng superb installation..
- Mar 2009
- 71
- Apr 2011
- 8
July 24th, 2011 02:51 PM #245sk lang mga master kasya ba kaya to sa din ng toyota revo namin Amazon.com: Pioneer DEH-4300UB CD Receiver with iPod/iPhone Control and MultiColor LCD: Electronics mineasure kasi nasa 7 x10x5 yung hu na stock
July 24th, 2011 08:13 PM #246
kasya yan sir, installer na bahala dyan, sa mgakinabit ko later sa revo, lahat po walang problem sa mounting except sa mga double din head unit, sa single din po, wala yan problema..
- Apr 2011
- 8
- Aug 2010
- 85
August 1st, 2011 07:07 AM #248mga sirs, patulong naman po magtono ng ampli, hindi ko po kasi alam kung pano magtono kasi gusto ko sana i-try kung pwede ko iset ng sq or boom2 type, hindi ko kasi alm kung san ko iseset yung Hz at ung Db, sana po may magturo magtono. baka po kasi pihit ako ng pihit masira ko yung sub. heeheh. salamat po!
2 - 12" DVC "OC12DVC"
1 - V12 MRV1507
1 - V12 MRV1608
- Aug 2010
- 85
August 1st, 2011 03:48 PM #249nag DIY po kasi ako dyan ako na din po gumawa ng box at yung mga subs and ampli ako na po nag konekta, kaya po yung pagtono medyo mahina po ako, nagbasa na din ako manual, nakakahiya man po pero sorry hindi ko kasi masyado maintindihan, sana po may mag explain po sakin. Thanks!
August 2nd, 2011 03:40 PM #250
Your sub would be fine as long as you put a subsonic filter in it. Having it play from 20hz to something like 150hz and it still would be healthy. However, most people cut it at 80hz.
The "DB" is the slope. Normally in increments of 6: 6db, 12db, 18db, etc. Slope, in a nutshell, dictates how "strict" your amplifier is in its cutoff. The steeper/higher the slope is, the more faithful it is to the cutoff. For starters, set everything at 12db.
With regards to SQ or SPL (boom boom), that depends on your definition on what SQ is. Most people define SQ in EMMA or IASCA standards: proper soundstage, tonal accuracy, spectral balance, etc. But in layman's terms, just adjusting the subwoofer amplifier's gain would probably dictate the bass "boom". Less gain = SQ. More gain = SPL.
Thread was made nung 2018 pa po sir.
