Results 1,201 to 1,210 of 3070
September 3rd, 2014 01:29 AM #1201
Kung marine series then yes the speaker is water-treated. These are usually installed in harsher environments like boats.
For the 1.1k, it's a coin throw really. Truthfully, I like the JBL MS62C. Its inverted dome tweeter is excellent and non-fatiguing to the ears (one of those dome tweeters that you get right) and inverted domes are inherently great in a small environment like a car due to their dispersion characteristics. Look at Focal and their obsession with it (they're the one who originally patented it). However, the 3dB sensitivity of the Infinity isn't to be scoffed at. That's huge.
September 3rd, 2014 04:12 AM #1202
Actually on paper the Infinity has 93dB sensitivity and 2ohm impedance while the MS62C has 86dB sensitivity and 4ohm impededance. I'll just to sleep it over na lang muna and think which should I get.
Follow up question lang po:
Ok lang ba na 2nd hand amps yung bilhin ko just to save some cash? Nakakita ako nag ad sa olx selling a Blaupunkt GTA 4100 4 channel at 5k.
- Jun 2010
- 72
September 3rd, 2014 06:39 PM #1203Sir may I ask for advise for the right size of subwoofer speaker for honda jazz. Since maliit lang naman ang interior nya and I'm more inclined on sq route, would an 8" subs will suffice my need. As of now I already installed 2-way seps powered by my HU only, I'm planning to install an amp to power the seps together with the sub but need to know the ideal size of subs based on the size of my car. Thanks
September 3rd, 2014 07:12 PM #1204
Wala naman right or wrong size nang subs, it's how much space you have and the space you are willing to give up that will determine the size of the subs. If you're really keen on saving precious boot space, you can make a sealed enclosure around .3-.5 cubft. for a 8 inch subs installed under the rear seats of your Honda Jazz.
- Jun 2014
- 64
September 4th, 2014 01:25 AM #1206
Oh right, different nominal impedance pala. If then so, you can't use sensitivity as a general comparison because a lower resistance would generally give you a higher measured decibel.
I also generally support secondhand amplifiers. Truthfully, I find snoopy's amplifiers at KAC's ICE section as a great buy.
September 4th, 2014 01:29 AM #1207
September 4th, 2014 07:30 AM #1208
- Jun 2014
- 64
September 6th, 2014 01:44 PM #1209Friends
Suddenly had a change of plans on going 3 way medyo need to go 2 way since i found the pillar mods a bit intrusive for my taste
Im working on a 80 to 100k budget so allocated 30k for install,deadening woodworks and wires
With 50 to 70k what can i do ?
I alreay have 2 4 channel amps already 4x100 each and have no plans on changing HU
Im planning on going focal flax audison bit tem focal p30
Would it make sense to change rear speakers to a coaxial ?
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
