Results 1 to 20 of 3070
    Aug 2010
    Quote Originally Posted by D3nb3r View Post
    I just want to confirm sir jhnkvn if the JBL MS62 na tinutukoy nyo is the same as the JBL MS62C? Yun kasi nakita ko sa mickey’s na site. The JBL MS62C is actually cheaper than Kappa 60.11CS by P1.1k. That’s a lot of savings (if mickey’s updated those prices). Mas mataas lang sensitivity nang Kappa 60.11CS. Also it says that it’s a marine series, does this mean also that the speaker is water resistant? Anyway, I’ll just download the MS62C pdf product guide for further reading.
    I don’t have a deep pocket and I’m not really particular sa brand nung speaker. It’s just that, with my limited knowledge in automotive audio it would be best if I stick to the well known/tested brands backed up by engineering/research, reviews and experts here in tsikot. I also believe that “you always get what you paid for”. If di pa kaya nang budget, I tend to save and research muna (like the 25k retrofit I shell out for my headlights) Kaya plan ko for my audio set up is to do it one at a time.
    It really pays to ask questions first, thanks sir jhnkvn
    Kung marine series then yes the speaker is water-treated. These are usually installed in harsher environments like boats.
    For the 1.1k, it's a coin throw really. Truthfully, I like the JBL MS62C. Its inverted dome tweeter is excellent and non-fatiguing to the ears (one of those dome tweeters that you get right) and inverted domes are inherently great in a small environment like a car due to their dispersion characteristics. Look at Focal and their obsession with it (they're the one who originally patented it). However, the 3dB sensitivity of the Infinity isn't to be scoffed at. That's huge.
    Mar 2012
    Quote Originally Posted by jhnkvn View Post
    Actually on paper the Infinity has 93dB sensitivity and 2ohm impedance while the MS62C has 86dB sensitivity and 4ohm impededance. I'll just to sleep it over na lang muna and think which should I get.
    Follow up question lang po:
    Ok lang ba na 2nd hand amps yung bilhin ko just to save some cash? Nakakita ako nag ad sa olx selling a Blaupunkt GTA 4100 4 channel at 5k.
    Jun 2010
    Sir may I ask for advise for the right size of subwoofer speaker for honda jazz. Since maliit lang naman ang interior nya and I'm more inclined on sq route, would an 8" subs will suffice my need. As of now I already installed 2-way seps powered by my HU only, I'm planning to install an amp to power the seps together with the sub but need to know the ideal size of subs based on the size of my car. Thanks
    Dec 2007
    Quote Originally Posted by enargie View Post
    Wala naman right or wrong size nang subs, it's how much space you have and the space you are willing to give up that will determine the size of the subs. If you're really keen on saving precious boot space, you can make a sealed enclosure around .3-.5 cubft. for a 8 inch subs installed under the rear seats of your Honda Jazz.
    Feb 2011
    Had a Jazz before and to save space, what the installer did before was to create a false floor. Since malilim naman ang trunk ng Jazz they added an additional layer on top of the original flooring so the amp and sub is becomes an integral part of the flooring. Search mo na lang sa KAC my rides section
    Posted via Tsikot Mobile App
    Aug 2010
    Oh right, different nominal impedance pala. If then so, you can't use sensitivity as a general comparison because a lower resistance would generally give you a higher measured decibel.
    I also generally support secondhand amplifiers. Truthfully, I find snoopy's amplifiers at KAC's ICE section as a great buy.
    Apr 2012
    sold na daw sir jhnkvn yung 2 crescendo amps ni sir snoopy
    Mar 2012
    thanks sir jhnkvn, have to visit KAC more often for those 2nd hand items. Problem is logistics since I'm form Mindanao
    That's ok, you'll never know baka bukas makalawa meron na naman mg benta nang amps nila.
    Apr 2012
    meron yan sir d3nb3r, lalo malapit na pasko maraming darating na good deals merong DLS A7 5ch amp binebenta sa fb ng car audio sale/swap kaso walang kontak yung seller it looks old na pero nasa 30k pa rin...
    Mar 2012
    good to know sir Monty but 30k is way above my budget for an amps. Budget meal lang kaya ko hehehe. I'm thinking of a Rockford Fosgate R400-4D lang.
audio set-up for beginners [continued]
