Not a guru here pero this might help.
Since ur amp is rate as 75 x 2 * 4ohms or 300 watts x 1 *4ohms,
best to wire your dvc sub to meet a 4ohm load (assuming its a dual 2ohm) by wiring it in series
you can do so by getting a wire to connect the + and - and then hooking the remaining + and - negative terminals to your amp's corresponding terminal in bridge mode.
Dual Voice Coil Wiring Options | KICKER
