Quote Originally Posted by acgq View Post
Sa mga gurus medyo naguluhan ako sa wiring. Ito system ko kicker cvr8 and punch 301s. Paano ba wiring gagawin ko sa dvc na cvr8? Puede kaya iparallel ko tapos bridge sa amp or 1st voice coil connect sa left ch ng amp then 2nd vc connect to right channel ng amp to make it stereo or mag series ako then bridge sa amp. Alin kaya ang maganda dito? Tia
Posted via Tsikot Mobile App
Not a guru here pero this might help.
Since ur amp is rate as 75 x 2 * 4ohms or 300 watts x 1 *4ohms,
best to wire your dvc sub to meet a 4ohm load (assuming its a dual 2ohm) by wiring it in series
you can do so by getting a wire to connect the + and - and then hooking the remaining + and - negative terminals to your amp's corresponding terminal in bridge mode.
Dual Voice Coil Wiring Options | KICKER
