Results 871 to 880 of 3070
- May 2013
- 37
December 20th, 2013 04:24 PM #871found DLS RS6N, how is this compared to Morel Maximo 6 and Focal na entry seps or similar price range? eto lang kasi afford ko kasi un morel and focal i think is 10k++ na. I would need to squeeze in an amp pa around 6500 para 15k ang total ko.
DLS RS6N + SoundMagus CK75.
ano masasabi niyo sir sa configuration na to?
December 20th, 2013 05:33 PM #872
Perfect Circle has competent installers naman. In fact, I believe most installers in Banawe are competent naman (if they aren't, how can they still be in business?) thanks to business necessity.
Tuning, on the other hand, is an art. It's art is because music is subjective. It's like tuning the ECU of your car, there's science behind it.. but most of it is art.
Same ba sila magtune? This unfortunately depends. Pure tuning as it is is easy on a regular setup as your tuning options are limited. Most have tone controls: treble, mid, bass to adjust and the occasional subwoofer level for the 2DINN models. The better ones have some sort of equalizer so you can adjust some frequency bands. The best ones have stuff like crossover, phase, time alignment, etc.
More important to getting something sound right in your car is the installation. Tama ba pagwire nila ng speaker wires? How is the amplifier's gain, crossover, and other settings? How is the attenuation of the tweeter? etc. Once this is done right, you then proceed to the tuning via the head unit.
If you hear the JBL sounds harsh, then you do two things:
(1) first is you fix the install side muna -- decrease the tweeter attenuation from the passive crossovers. Meron yan mga +dB, 0dB, -dB and you adjust that to "tame" how much your speaker shouts at you. If it shouts too much, this will come off as too "harsh" for the listener. The need for this stems from the sensitivity of the driver kasi. If you feed a tweeter 1W, most of them will produce 95dB.. if you feed a midbass 1W, most of them are in the 90dB. In other words, your tweeter is shouting at you and the midbass is barely moving. That's why you need to "balance" them by attenuating or reducing the tweeter level in accordance to the midbass.
(2) Once the install side is done, you then try to tune it via the head unit. If you have tone controls, you'll be looking at reducing your treble primarily. If you have a graphic equalizer, you'll be cutting at the 1khz to 5khz region in most cases.
How much an installer needs to tune depends on your gears. Don't expect the best unless you give them the best. It's like you shouldn't expect 1000HP out of a stock RB26DETT GTR engine if you do not plan on getting "better" parts.
If you wanna know how much "professional" tuning is in the Philippines (assuming you have good gears), one-off tuning will cost you from the well-renowned car audio shops will go around Php12,000+ and this may go even more depending on the complexity of your system.Last edited by jhnkvn; December 20th, 2013 at 05:39 PM.
- May 2013
- 37
December 21st, 2013 12:15 AM #873sir jhnkvn, updated price po ba nung morel maximo 6 is 6-7k lang? Parang sabi sa back read ko na introductory price lang un and now mga nasa 10k-ish na price niya. Paenlighten naman ng price talaga nito. And pahingi naman po tips sa seps among maximo 6, DLS RS6N or Focal pero mukhang malabo un budget ko for focal.
Maximo 6 vs DLS RS6N?
December 21st, 2013 03:18 AM #874
- May 2013
- 37
December 21st, 2013 05:37 AM #875
December 21st, 2013 09:43 AM #876
December 21st, 2013 01:31 PM #877
Because at these price points, lahat sila more or less same materials lang ginagamit. And this makes it hard to differentiate them. Not that it's anything bad but sometimes you have brands that standout because of their engineering. For example, Focal is well-known sa inverted tweeter domes nila. Morel pioneered the carbon fiber sandwich on their Fat Lady flagship speakers, JBL is very famous sa GTi subwoofers nila because it uses an underhung magnet to reduce distortion, Scanspeak's slitted treated paper cones, etc.
When it comes to the lower price bracket. It's not really all that important to get best speakers because there's no best. Because of price point, limited sila on what they can throw sa speakers nila. "You can't throw a 50,000php beryllium tweeter sa 5,000php na speaker" so parang ganun na yun.
The reason why people continue to shell out big bucks is always on one premise: "tingin ko masmaganda tumunog si X kaysa sa current ko" This is true in a way because better equipment will always be more capable than budget ones. But it doesn't mean they sound better. Yun problema kasi sa industry is that they correlate "better" with more expensive. May makita lang silang brand name ng Focal parang "shet.. mahal at maganda". But fact is, I never had people who sat in my car.. listen to my system.. and know my system. That's a huge revelation is because your ears -- or somebody's ears won't really care about which brand. But when we start seeing things using our eyes.. our perception of sound changes.
If you look at it in a strict SQ criteria, I will guarantee you: you cannot differentiate them apart if I blindfold you. But once I remove the blindfold, I suggest you purchase the speaker na tingin mo.. masmaganda sayo. Because user perception is automatically +50% SQ points sa iba.. hehe.Last edited by jhnkvn; December 21st, 2013 at 01:36 PM.
- May 2013
- 37
December 21st, 2013 03:08 PM #878Hmmmm, if kukunin ko un JBL, is there a guarantee na matutune ng shop ito in such a way na hindi matining or masakit sa ears un highs niya? and also, should I just spend the extra na natipid ko sa seps and buy a more expensive amp? ~8-9k amp instead of nasa mga 6k amp lang. May sub and HU na kasi ako.
- May 2013
- 37
December 21st, 2013 05:52 PM #879sir jhnkvn, quickly nalang, 7500 for the morel maximo 6, 8k for the DLS RS6N, you said na you'd go for morel parin. why? for extra 500, isn't un reference series ng DLS is on par with entry ng Focal? which makes it a tad higher than morel right? Why would you choose morel parin over DLS reference? Thanks.
- May 2013
- 37
December 21st, 2013 06:59 PM #880may mga nabasa din ako mga post niyo nuon na sabi niyo,
Focal's entry levels seps -- 165A1 Access should cost around 9k retail. 8500php after haggling.
I don't like DLS X-Program at all. IMO, best enter DLS at RS6.
Focal's entry-level Access lineup is still expensive kahit sabihin natin "entry". It's priced around 7-8k AFAIK. It's peer is DLS RS6.
Morels take 2nd place. I like their tonal quality but their highs might leave you a bit dazed. Madami umaagal that they're too "bright"
well sabi niyo some say morels are bright, and tinignan ko un manual nung morel maximo, I think walang attenuation controls un tweeter nito, so hindi kaya maging problem kung bright sounding siya kasi no more control to correct it? Or the EQ controls from the HU would be enough naman to "tame" un bright sound. Correct me if I'm wrong.
Also, if you have any idea po ano sound signature ng DLS RS6N? and morel maximo?
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
