Minor upgrade only. Changed stock AVT head unit to Pioneer AVH-275BT. Changed stock front seps to DLS Matador MK6.2 seps. No change on the rear yet. Installed at Winterpine, Araneta Ave, QC.
The stock speakers of ASX after removal..
ask lang po ako, need lang ng advice. ano mas better for my setup i have a sound magus dk600 amp 600wrms 2 ohms 300wrms 4ohms currently running 1 kicker comp d 12" 4ohms dvc (wired to 2ohms) hindi po kasi match ung amp at sub ko kaya i was thinking to change to 2 kicker comp s 12" 4ohm subs so i have 600wrms total. but i was wondering if getting a comp r 12" 4ohms dvc sub 500wrms would be better. below are short specs for reference ng 2 subs. itong dalawa lang pinag pipilian ko po kc ito lang kaya ng budget na mejo known trusted brand.
2 kicker comp S 12" (300w rms (600w max) Sensitivity (dB 1w/1m) 88.3 27-500hz response)
or
1 kicker comp R 12" (500W RMS (1000W max) Sensitivity (dB 1w/1m) 86.9 25-500hz response)
or
Hello po fellow car owners. Baguhan lng po ako at super noob sa sasakyan. May tanung lng po ako. Kabibili lng po kasi namin ng 09 innova E. Bali gusto ko po sana magkaron ng bluetooth compatibility yung head unit. Stock lang po kasi siya, am/fm and cd player. Pano po ba magkaron ng bluetooth compatibility? Papalitan po ba totally yung HU? Or may ikakkabit lng na bluetooth receiver? Looking forward on your replies mga sir!
Meron bang USB port ang stock HU mo? If yes, try mo maghanap ng USB Bluetooth receiver dongle.
Or meron bang AUX in ang stock HU mo? If yes, try mo maghanap ng Bluetooth receiver dongle with 3.5mm output.
If parehong wala, then palit HU lang ang solution.
*red_one, i got similar one, the 2750BT, I'm planning to install it in my grandia van...
what speakers and sub did you matched it with?
thanks sir, magkano presyo ng dls matador?
i am currently deciding anong front seps, coax at sub i-upgrade ko to match sa 2750BT HU ko para sa grandia van. it's a huge van so need ng rear (coaxial) speakers sa likod. i have in mind try ko mag straight JBL, pang budget set-up lang...![]()
I am planning to have my stock HU on my jazz changed for me to be able to install a back up camera, and since I am going to change it, any recommendations for a decent HU that could also improve sound quality of my stock setup? with plans of adding sub and tweeters next... really have no idea about sound setups... thanks for inputs..
