Results 751 to 760 of 1645
- Apr 2006
- 200
January 14th, 2007 01:04 AM #752MGA SIR NAG CANVASS PO AKO SA BANAWE...
SA TAGAL KONG NAGHANAP ito ANG OFFER SAKIN ng isang STORE..
Im Newbie sa Car sound setup kaya pinakamura muna hinanap ko...
( SIRA NA KASE STEREO at SPEAKER kotse kaya napilitan magpalit )
1 pc PIONEER DEH 2950 Mp3, AUX in, WMA
2 pcs PIONEER TS-A6981R REAR SPEAKERs
6" x 9" 4-Way Speaker with 420 Watts Max. Power
2 pcs PIONEER TS-A1681R FRONT SPEAKERs
6½" 4-Way Speaker with 260 Watts Max. Power
1 pc V12 Amplifier ( For front & rear speaker daw? )
1 pc V12 Subwoofer 10 inches with built in amplifier ( me box na pahaba )
( all includes labor, wiring kit, Y connector, RCA )
ALL FOR P 19,800.. MGA SIR MAKATARUNGAN PO BA TO?
WHAT DO YOU THINK WILL BE THE OUTCOME?
IM LEANING ON SOUND QUALITY....
ANY INPUTS WILL BE APPRECIATED.. TNX
PS.. KAILANGAN KO PA BA NG 2 TWEERERs kase sabi nung Electrician
kahit di na daw kase 4 way na yung front speaker...Natutuwa
kase ako sa Tweeters kaso dagdag gastos pa..hehe..Tnx
- Jul 2006
- 21
January 23rd, 2007 05:46 PM #754
- Oct 2006
- 114
January 23rd, 2007 06:04 PM #755
January 24th, 2007 04:53 AM #756
Tsikot Member Rank 3
- Jul 2004
- 1,540
January 29th, 2007 12:24 AM #757Mga sir, question po. I'm looking for an amp to power my 10" CVR 4 ohms.
Choices ko Lanzar HTG244 (5.5k), Blaupunkt GTA1300 (7k) and Pyramid PB1080 1200W http://kotseaudioclub.com/forum/viewtopic.php?t=20285 (8k)
all are 2nd hand. Ano po ba pinakaokay for my sub?
thank you!
January 31st, 2007 04:45 PM #758
I just got the Pioneer 2950. As of now, im using Targa X series seps for the front, and moved my kenwood stock speakers to the rear temporarily. I have no amp, but will get one when I get my sub next month. I'm running my Seps directly from my 2950. I'm not THAT happy about the sound, it's mediocre.
Question:When I run my seps through the amp, will it sound more clean, n loud n have some good midbass? Or will a crossover do the job? or both? I think my headunit is the problem, i played around with the sounds, and i just can't seem to get the nice midbass/bass sounds, and the voice isn't as clear as i'd like it to be.
February 3rd, 2007 05:16 PM #759
btanong ko lng mga tol kc sinubukan ko i-amp ung 2 speakers ko sa likod na pioneer sa 4ch amp ko n nkakabit \dun ung 2 10" subs tapos nag static na kaya tinanggal ko uli ung 2 pionner n speaker sa amp tapos ganun na uli nagstatic pa rin. Ano dapat ko gawin para mwala uli ung static?
February 4th, 2007 03:43 AM #760
--AFAIK, okay naman yun 2950 mo (may built-in HPF & LPF yan na pwede mo kalikot para yun highs and mids sa harap lang lalabas). Try mo also kalikutin yun FIE (Front Image Enhancer) para yun lows na sound nasa rear speakers mo lang lalabas.
*[SIZE=2]High Pass Filter: If you do not want low frequency sounds to play from the front or rear speaker outputs, you can turn on the 12dB/octave High Pass Filter. The HPF has a selectable cutoff frequency (50, 63, 80, 100, or 125 Hz). Only frequencies higher than those in the selected range are output through the speakers
*[/SIZE][SIZE=2]Front Image Enhancer (FIE): The Front Image Enhancer attenuates mid- and high-frequency sounds from the rear speakers at selectable crossover points, so that most of the vocals will come from the front speakers, giving you better image staging. You can select from the following cutoff frequencies: 100Hz, 160Hz, and 250Hz.
**taken from www.pioneerelectronics.com**
[/SIZE][SIZE=2]--Hope this helps sir.
[/SIZE]
Wow. No brainer to get the totl turbo over the seltos sx 1.4 turbo that also costs around 300k plus...
2022 Hyundai Creta
