Results 1 to 20 of 1645
    I just got the Pioneer 2950. As of now, im using Targa X series seps for the front, and moved my kenwood stock speakers to the rear temporarily. I have no amp, but will get one when I get my sub next month. I'm running my Seps directly from my 2950. I'm not THAT happy about the sound, it's mediocre.
    Question:When I run my seps through the amp, will it sound more clean, n loud n have some good midbass? Or will a crossover do the job? or both? I think my headunit is the problem, i played around with the sounds, and i just can't seem to get the nice midbass/bass sounds, and the voice isn't as clear as i'd like it to be.
    Quote Originally Posted by KrisKros View Post
    --AFAIK, okay naman yun 2950 mo (may built-in HPF & LPF yan na pwede mo kalikot para yun highs and mids sa harap lang lalabas). Try mo also kalikutin yun FIE (Front Image Enhancer) para yun lows na sound nasa rear speakers mo lang lalabas.
    *[SIZE=2]High Pass Filter: If you do not want low frequency sounds to play from the front or rear speaker outputs, you can turn on the 12dB/octave High Pass Filter. The HPF has a selectable cutoff frequency (50, 63, 80, 100, or 125 Hz). Only frequencies higher than those in the selected range are output through the speakers
    *[/SIZE]
    [SIZE=2]Front Image Enhancer (FIE): The Front Image Enhancer attenuates mid- and high-frequency sounds from the rear speakers at selectable crossover points, so that most of the vocals will come from the front speakers, giving you better image staging. You can select from the following cutoff frequencies: 100Hz, 160Hz, and 250Hz.
    **taken from www.pioneerelectronics.com**
    [/SIZE]
    [SIZE=2]--Hope this helps sir.
    [/SIZE]
    [SIZE="5"]Anybody knows price ng Targa 15" and 12" Subwoofer sa Raon?[/SIZE]
    MGA SIR NAG CANVASS PO AKO SA BANAWE...
    SA TAGAL KONG NAGHANAP ito ANG OFFER SAKIN ng isang STORE..
    Im Newbie sa Car sound setup kaya pinakamura muna hinanap ko...
    ( SIRA NA KASE STEREO at SPEAKER kotse kaya napilitan magpalit )
    1 pc PIONEER DEH 2950 Mp3, AUX in, WMA
    2 pcs PIONEER TS-A6981R REAR SPEAKERs
    6" x 9" 4-Way Speaker with 420 Watts Max. Power
    2 pcs PIONEER TS-A1681R FRONT SPEAKERs
    6½" 4-Way Speaker with 260 Watts Max. Power
    1 pc V12 Amplifier ( For front & rear speaker daw? )
    1 pc V12 Subwoofer 10 inches with built in amplifier ( me box na pahaba )
    ( all includes labor, wiring kit, Y connector, RCA )
    ALL FOR P 19,800.. MGA SIR MAKATARUNGAN PO BA TO?
    WHAT DO YOU THINK WILL BE THE OUTCOME?
    IM LEANING ON SOUND QUALITY....
    ANY INPUTS WILL BE APPRECIATED.. TNX
    PS.. KAILANGAN KO PA BA NG 2 TWEERERs kase sabi nung Electrician
    kahit di na daw kase 4 way na yung front speaker...Natutuwa
    kase ako sa Tweeters kaso dagdag gastos pa..hehe..Tnx
    Saw ur post, I was in Del Monte naman last Sunday to canvass a sound set-up, medyo newbie pa lang din..
    I was able to visit Spinner, talk to Lito..
    HU Pioneer DEH 2950 - P 5000
    Sub-bazooka type 8 inch - P 2,500
    Separates Kicker - P 3,500 if im not mistaken
    wiring kit - P 1000
    cost around 12K lng, di na daw kailangan ng amplifier as he said dhil amplified na yung Sub..
    Ok na kaya to for SQ lang? Appriciate your response..Thanks
    Jul 2006
    mga sir...newbie lang po sa sound setup....I have a toyota innova and gusto ko sana i-setup ung sounds... My HD is a fujitsu 2-din. kailangan ko pa po bang palitan un to have a good quality sa sounds? d ko naman po kasi gusto ung sobrang ganda..kahit konting bayo and medyo malinaw ang tunog masaya na ko.. ano po ba dapat palitan at ilagay ko? thank you in advance sa mga inputs niyo. and by the way gusto ko sana mga 10k to 12k lang ang ibbudget ko.
    Opinion ko lang paps para super tipid wag mo na palitan HU mo. CD na ba yun? Then buy ka seps and sub na Targa plus V12 na 1507 na amp or kung gusto mo mas malinis tumunog try mo mga fenton.
    Jul 2006
    Quote Originally Posted by zanch View Post
    actually mp3 player na siya bro..cge try ko ung targa and fenton...tnx bro..
    Ayus pede na sya bro! Ginawa ko kasi dati pumunta ng raon ng mga gamit like seps and subs then pinakabit ko sa installer ko. mas mura kasi dun bro. isa isahin mo lang mga shop dun then kuha ka sa pinakamura. Then pakabit mo nalang sayong suking installer.
    Feb 2010
    ask ko lang po kung paano pagset-up ng wiring ng amp. wala kasi siyang remote or power antenna connection sa HB? pls help ty
    Mar 2007
    Any shop sa Laguna na pwedeng mag ayos ng set up ko? malaki kasi masyado ang subs ko, di na mapakinabangan ang compartment, gusto ko sanang ipaayos yung may porma na ng konti...baka may ma advise kayo kung saan sa Laguna and how much po ang possible price? thanks..
    Feb 2010
    newbie lang po ako, ano ang magandang imatch na amps para sa Infinity subwoofer (series 301)? ang car ko po ay 1989 corolla. ang puwede kaya magpalit nang head unit dahil yung kasama sa kotse hindi maread ang mp3 discs.
    Aug 2004
    ser sino kaya puede magbigay ng tips/pointers/ for DIY or pagawa sa labas ng Sound setup for Carens.....
    lalo na yung setup ng Sub-Woofer nya to fit right inside the rear quarter panel hole and small AMP to power it.
    Feb 2007
    May X-over na dapat yung separates ah. I use Kicker separates. Its good.
    Quote Originally Posted by raphael_allen View Post
    Thanx... maybe next month i'll do that. I saw your setup on the other thread..How do you like your 2950 overall? N Hows the sound with 2 amps? N sound of the subs with the 2950? Ok lang ba? Also..heheh how much kaya are kicker seps?
audio set-up for beginners (ARCHIVED)
