Results 111 to 120 of 157
- Jun 2012
- 269
December 25th, 2023 09:18 PM #111
- Jun 2005
- 3,774
December 25th, 2023 10:48 PM #112Ano ba unit mo? Pero anyway willing to pay ka naman eh. Hehe
Sent from my 2107113SG using Tsikot Forums mobile app
- Jun 2012
- 269
December 26th, 2023 12:39 AM #113
- Jun 2012
- 269
December 27th, 2023 12:33 AM #114Update and early feedback sa STAPON 8/128gb:
Napa install ko na kanina. All goods naman, ginamit ko na lang ung stock reverse cam. Kaso "lumabo" kasi na stretch ung image, di ko lang sure if mas "okay" if ung freebie reverse cam ung ginamit ko.
Hindi na nag splice for steering wheel except for ground and reverse cam iirc.
Then habang nag e explore ako biglang di gumana ung touchscreen and buttons buti nalang na fix via plugging usb mouse then calibrate ng touch screen as per seller.
Hindi din ma customize ung homescreen, pwede lang mag add and remove ng small widget pero ung existing na malaking widget is ayaw.
Hindi ko pa na try ung sa sim card kasi di pa ko nakakabili para sa sariling data. Need muna i register sa phone bago ilipat. Pero okay naman connection nung nag hotspot ako sa phone.
Smooth siya overall hindi lag while using Google Maps and Spotify except while connecting and reconnecting sa carlink via Android auto. Youtube is okay din pero sa netflix need daw ng lumang version.
Kaso issue ko ngayon is ang bagal/tagal mag connect to android auto (carlink ung app sa HU). Nag order ako online ng new usb to type c, sana mag improve.
Any suggestions sa settings ng equalizer and all?
- Sep 2016
- 2,348
December 27th, 2023 12:21 PM #115
- Mar 2014
- 697
December 27th, 2023 01:15 PM #116Sa Joying unit ko, I prefer using Waze installed there rather than connecting my phone and run Android Auto. Nilagyan ko nalang ng no expiry GOMO SIM para always may internet.
- Jun 2012
- 269
December 30th, 2023 12:45 AM #117
- Jun 2012
- 269
December 30th, 2023 12:51 AM #118
- Dec 2023
- 30
December 30th, 2023 01:56 AM #119Toyota Innova 2017: I just installed an Astral 13inch HU, 4G RAM, 64GB ROM. I paid 22k with free rear camera installation and free plastic dashboard frame that fits to the 9inch extension frame that comes with the HU. I haven't checked if the specs are true and I'll update this post once I've tried it.
Astral branch: EDSA Cubao at the Clean Fuel Gas Station.
Service: excellent, fast, and they really know what they were doing. The rear camera needed splicing from the reverse lights.
Actual HU: actual screen size is 12.9inch, as per barcode label but marketed as 13inch. Most likely the 13inch advertised included the border of the unit. Crisps 2K resolution naman, 1920x1200 resolution. Has 3 height levels, I choose the middle height because when it is really high it covers the hazard button, and when it js low it obstruct he A/C controls. Even with the middle height, the hazard control is difficult to press since it's nearly obstructed.
Free rear camera: is not HD. Not very clear resolution. The technician was saying this is not compatible with HD camera. They suggest that I purchase a rear camera with night vision.
360 Camera: Supported out of the box. But I didn't purchase from Astral. I didn't want to have my side mirror to have a hole. Maybe in the future if I change my mind, I might buy those side camera and activate the 360 camera.
Steering wheel control: programmable. My innova 2017 G variant has few controls. It worked well and was easy to program
4G antenna and GPS: supported and installed on site. I haven't purchased a sim card for the 4G data. The GPS works well when I used Google maps. Not sure of I can use the GPS to track my car if it gets stolen because the HU only opens when you power and start the car. So, probably it can Tract when the car is moving and engine is open.
Android Auto/iOS Carplay: Supported.
DSP: Supported, was able to enhanced the quality of my stock stereo speaker. I'm not an audiophile, but it sounded good to me already.
BT: supported. Connects really fast.
Android apps: playstore is available. Netflix and Chrome installed out of the box.
Factory password: 3368
Brightness: very bright at night. So you might want to set brightness level to "0" at night so as not to distract you from the road. I haven't tried in the morning, but it really seems very bright..
I hope this is helpful. Sorry if this is long.
P.S. I couldn't find the OEM even with this serial number. It didn't have any manual in the box. Either the supplier removed the manual or it's really a generic HU without any. I'll keep searching.
- Dec 2023
- 30
December 30th, 2023 03:30 AM #120Toyota Innova 2017: I just installed an Astral 13inch HU, 4G RAM, 64GB ROM. I paid 22k with free rear camera installation and free plastic dashboard frame that fits to the 9inch extension frame that comes with the HU. I haven't checked if the specs are true and I'll update this post once I've tried it.
Actual HU: actual screen size is 12.9inch, as per barcode label but marketed as 13inch. Most likely the 13inch advertised included the border of the unit. Crisps 2K resolution naman, 1920x1200 resolution. Has 3 height levels, I choose the middle height because when it is really high it covers the hazard button, and when it is low it obstruct he A/C controls. Even with the middle height, the hazard control is difficult to press since it's nearly obstructed.
camera.
purchased a sim card for the 4G data. The GPS works well when I used Google maps. Not sure of I can use the GPS to track my car if it gets stolen because the HU only opens when you power and start the car. So, probably it can Tract when the car is moving and engine is open. Android Auto/iOS Carplay: Supported.
Brightness: very bright at night. So you might want to set to "0" the brightness level at night. I haven't tried in the morning.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
