Page 114 of 392 FirstFirst ... 1464104110111112113114115116117118124164214 ... LastLast
Results 2,261 to 2,280 of 7833
    Jul 2013
    #2261
    845 is already a good LSP with its high gloss shine and durable weather protection, to top it with another product is just a waste of money and time
    thanks for the kind advice sir. hirap kase pakintabin ng quartz brown.
    #2262
    Double coat Collinite 915
    Apr 2012
    #2263
    Quote Originally Posted by LLOY View Post
    to bring out the shine, kailangan ma-prepped na mabuti yung paint surface. need mo washing, claying, polishing, finishing then apply the LSP's. pwede rin by hand lang pero mas maganda kapag may gamit ka like orbital polisher at mga polishing compounds. kapag wala ka gamit much better to bring it to a good detailer shop para paglabas makintab yung quartz brown mo. then from there, I-maintain mo na lang ng wash and wax mo ng 845. after many washings at wala na naman kintab, pasyal ka na naman sa detailer mo
    Aug 2013
    #2264
    Good day mga guru kung saan makaka bili ng collonite 476s. wala kasi ako mahanap sa mga retail store e.. sana matulungan nyo ako. thanks!
    #2265
    Quote Originally Posted by Anakid View Post
    At Autobisyo in Laguna, near Southwoods exit and Splash Island. You can google contact details.
    Aug 2013
    #2266
    Quote Originally Posted by loverlionus View Post
    sir, out of stock daw po.. matagal pa bago mag karon.. bukod po sa Autobisyo saan pa pedeng maka bili? thanks po
    and ask ko lang rin po ung carcover ko po parang dumikit dun sa may windshield ko .. anu po kaya pang alis dun parang maliit na mark sya
    parang acid raid halos.. pa help po TIA
    May 2011
    #2267
    Guys pwede na buff machine gamitin pang alis mg 476s collinite? Kakapagod sobra magmaanual papatira ko nalang sa detailing shop
    Sent from my HTC Desire V using Tapatalk 4
    Aug 2013
    #2268
    Sir 3GEMS
    ask lang po regarding 476s. saan po kayo naka bili nyan? plano ko kasi bumili rin.. sana matulungan nyo po ako maraming salamat.
    Aug 2008
    #2269
    Interesting - there used to be several sellers on Sulit, but looks like they're all sold out as well. For watermarks on glass, Microtex has a Stainz Out product which works, though does require some effort. I've also used Mothers Water Spot Remover, which seems a bit more effective, but is a little more expensive, and you need to wipe-off trim sooner.
    Aug 2008
    #2270
    Quote Originally Posted by 3GEMS View Post
    You can use a DA with a microfiber bonnet to remove. I wouldn't recommend using a rotary though, as the direct rotation might be too aggressive and remove too much of your wax layer.
    Aug 2004
    #2271
    Tried out a surplus AEG EX 150 E last long weekend. Speeds were in letters (A, B, C up to I think H) instead of the usual numbers. Used 6" Chemical Guys Orange pads to apply Poliseal on speed "D".
    The goal was to remove overspray from my hood but it looks like Poliseal does not have enough bite to remove it. Some of the roughness was removed but it's still not as smooth as I want it to be. What's the next step? Nanosil or M205? Or increase the speed? I'm afraid of destroying the pads. They don't come cheap
    May 2005
    #2272
    Puwede naman but use the least agrresive pad. Puwede naman by hand eh and madaling tanggalin for as long as
    1. Dont let it sit too much. Pag yan natuyo, daig mo pa nag gym sa pag buff out nyan
    2. Apply as thin as possible. It would appear as if walang wax na nilalagay but look closely and youll see na meron na manipis na layer. Yan ang tama
    3. After buffing it out, Use your clean and plushest mf towel to do a final wipedown para matanggal trace wax
    Apr 2012
    #2273
    poli-seal is a very good 1 step product. if di kaya over spray then use a more agressive product. try the least agressive product, you can try M205 but its also a finishing polish, so maybe it will not have that much bite too. if you have M105 then i'm sure it will have a good bite, test it first in a small area and check the result.
    Aug 2010
    #2274
    *JohnM
    Although they used polishing products and a wool pad to remove surface contaminants before, I won't suggest it as that's a pretty extreme method of doing things. Try to first assess the extent of the overspray (is it like sandpaper like na? etc.) and use the appropriate detailing clay to address it.
    Once you see the amount of contaminants being bonded to the paint, you'll be wondering if it's even a good idea to use a polish and a machine to remove these. Personally, I'm meticulous on those particulars so I usually clay first then followed by your detailing regimen rather than saving a few pennies down the road.
    Aug 2004
    #2275
    I tried claying it before. Di talaga natanggal. I could be using a very fine clay though. Ok lang siguro sya for libag. Then I tried hand-applying Poliseal. Nabawasan ang gaspang onti. Topped it with 845 and left it for few months. When I got the DA and orange pads sinubukan ko uli with Poliseal. Malaking improvement pero may mga spots pa rin natira. Pwede ko naman pasadahan pa uli pero I was thinking of upping the cut with Sil. Mukhang mahal si UC or 205 eh.
    After two years medyo madami na rin akong swirl marks so I was thinking sabay na lang. Nakakainis kasi magpunas ng oto tapos may parts na makinis then biglang magaspang
    Aug 2013
    #2276
    hello po, ask ko lang po kung tama po ung magiging procedure ko
    car wash > nanosil > M26 yellow wax > cure? then after next car wash nano sliq?
    hope matulungan nyo po ako thanks
    Jul 2013
    #2277
    A week old 845 maintained with moms fx. . Share lang po.
    Apr 2012
    #2278
    A week old 845 maintained with moms fx.[IMG]http://i1286.photobucket.com/albums/a603/naima_ferjan08/4756AEEA-850B-46A5-8738-CCA36DBD79CC-499-0000004506922B2C_zps09364cb7.jpg [IMG]http://i1286.photobucket.com/albums/a603/naima_ferjan08/57E2B74E-7B31-4934-A5E1-7BE2DACC2E82-499-00000044FC204D9A_zpsd089954d.jpg. Share lang po.
    wow! GTV limited edition. to maintain the gloss and minimize the swirls, learn proper washing (2 buckets) and drying. then to protect the paint, apply a good and durable sealant or carnauba wax
    Jul 2013
    #2279
    sir, what i have in the garage is 845,megs cleaner wax,Fx spray wax,microtex poducts(glos,sil,sliq and wash and wax)and some 3m products. is this ok na po ba to sir for maintainance ng gloss?
    Aug 2013
    #2280
    hi mga gurus.. just wanna ask po.. ayos lang ba mgiging regimen ko?
    malapit ko na makuha yung new car ko.eto sana plan ko..
    KAIO then KSG cure for 24 hrs then apply KSG again cure for 24Hrs again (KAIO/KSG - quarterly)
    then apply 476s let it cure (476s - monthly)
    then apply OCW or UQW in top of 476s (-every 2weeks or so)
    lastly maintain with OID-GE every wash? thanks..
"Tamang OC lang" - a newbie's guide to car appearance maintenance
