Page 41 of 127 FirstFirst ... 313738394041424344455191 ... LastLast
Results 801 to 820 of 2535
    #801
    Quote Originally Posted by indiej View Post
    Mother's/Meguiar's Step 1 are pre-wax cleaners. Hmmm, your post count is ten times mine already. Which section in the forums have you been frequently helping out the tsikoteers?
    Nagpaparami lang ng post count......
    Ngayon ko lang ulit nalinis ng seryoso yung Tucson ko Umpisahan ko na mag-wax mamaya.
    Aug 2010
    #802
    Wag Ken, tinignan ko weather app ko puro thunderstorms daw eh :naughty2:
    #803
    Quote Originally Posted by jhnkvn View Post
    Ikaw lang ba meron?
    Bago na cellphone ko eh. Yun din sabi sa iPad. :hysterical:
    #804
    sabi ng tablet ko 300mb of 500mb downloaded, eh... whoops... weather ba pinaguusapan?
    Aug 2011
    #805
    Guys,
    Anong cheap sealant at quick detailer ang ok i partner sa OCW?
    I recently purchased ONR and OCW. My wallet got broke.
    Aug 2008
    #806
    Quote Originally Posted by vefyjeph View Post
    Guys,
    I would say Opti-Seal, but a cheaper alternative would be 3M Performance Finish. For QD, you can use ONR in QD dilution (1:16) as a cleaning QD; for a QD to add gloss and slickness, NanoSliq works well, and at a good price. You can even dilute NanoSliq 1:1 with water, to reduce streaking (I also dilute it with 1:1 with ONR QD, for additional lubrication).
    Aug 2011
    #807
    Quote Originally Posted by umi001 View Post
    Ubos na yaman ko kung kumuha pa ako opti-seal at collinite wax.
    Thanks for the cheaper alternative... Can I use the 3M performance finish alternately?
    1. Wash
    2. 3M performance finish. Let cure for 24hrs?
    3. Nanosliq+1:1 water solution
    kapag nagdumi or after 1 week
    4. Wash
    5. OCW (Let cure ulit?)
    6. Nanosliq+1:1 water solution
    Bronze color ng car ko and 1 month pa lang... NanoGloss and NanoSliq combo ginamit ko sa loob ng 1 month.
    Jan 2012
    #808
    Hanggang ngayon hindi parin ako nagccome up sa magandang regimen for my monty. Im just using the glos and sliq combo. Hehehe nakakainis pa tubig namin dito nagkaka-watermarks tuloy kotse! Badtrip!
    #809
    Quote Originally Posted by carwhacko View Post
    Yan ang mahirap sa tubig sa province, pards Pag naka pressure washer ka naman pino yung water spots.
    Pero try mo kung may pressure washer ka, lagyan mo ng filter yung gripo
    Jan 2012
    #810
    Oo nga eh. Bad vibes ako lage pag naglilinis. Salamat boss, tagal pa pati ng maynilad umabot dito. Hehehe
    Aug 2008
    #811
    1. Wash
    4. Wash
    I'd simplify things a little - you can go something like week 1 3M, week 2 NanoSliq, week 3 OCW, week 4 NanoSliq, then repeat. Heck, I'd have no problems going week 1 3M, week 2 and 3 Sliq, week 4 OCW, week 5 and 6 Sliq, then repeat - both the sealant and the wax should be durable enough for that.
    Sent from my GT-P6800 using Tapatalk 2
    Feb 2012
    #812
    saan nakaka bili ng Klasse product???
    meron ba sa Banawe? at how much?
    Aug 2008
    #813
    Quote Originally Posted by civilcode View Post
    You can get Carlack - which is the virtually the same product, rebranded (actually Klasse is the rebrand) - from Big Berts and some MC Home Depots. 2,600 for the twins.
    Aug 2011
    #814
    Thanks for this. My car had some watermarks due to the carwash done by the CASA when I had a change oil.
    I washed my car again using ONR. Then applied OCW while car is still wet and dried it. Tama ba itong process na ito?
    I noticed that there were still some watermarks left. So I guess ONR and OCW cannot remove these. I applied nanogloss in the watermark and removed some of them. I am not sure if it removed it or just hide it.
    I guess I need cleaner wax or pre-cleaner wax muna for these watermarks before applying OCW.
    Aug 2008
    #815
    ONR washing doesn't leave a lot of solution on the panel, so it should be fine - though what you can do is do a first drying pass with one MF to get most of the water off the car, then spray OCW and finish drying afterwards.
    ONR and OCW won't remove watermarks. NanoGlos has some cleaning ability, so it can remove some of it, but you're right - a proper cleaner wax or pre-wax cleaner would be a better option.
    Aug 2011
    #816
    Thanks again umi001...
    I was able to remove most of the watermarks using ONR with QD strength... I read somewhere in these forums to start with the least abrasive method first in removing watermarks. I think there is only about 3-5 small dots left on my hood. So this means the next one which is the pre-cleaner wax. I went to blade/true value in park square and found meguires/mother's pre-cleaner wax/step1. Medyo pricey pala sila. Well, kasi malaki bote for aboth 500+ pesos.
    Then since I am now paying attention to my paint, I noticed naman now na parang meron about 5 very small biloys. Parang sa clearcoat lang ang affected. Parang butas na kasing laki ng lang ng tuldok. Baka nalagyan ng alikabok nung nag-apply ng clearcoat ang factory? May solution ba dito o wag ko na lang pansinin?
    May 2012
    #817
    good day mga sir, need ko lang po ng inputs niyo regarding po sa Turtle Wax Platinum Liquid Wax? and Turtle Wax Ice Liquid wax? ano mas better sa kanilang dalawa mga sir? ano po sa dalawa ung mas matagal matanggal? And pwede po ba patungan ng Mothers FX Spray wax ung Turtle Wax? Wala po kasi time para sa Mothers 3 step. Pasensya na po mga sir newbie palang po ako sa detailing. Thank you.
    Aug 2008
    #818
    Quote Originally Posted by Type_Z View Post
    I've not used the products, but based on everything I've read, I'd go for the Platinum wax (though probably the paste version, just because I'm partial to paste waxes myself ) - in fact I'm planning on adding TWPUG paste to my collection. The FX spray would be fine, though depending on the car color, the Reflections Spray Wax might be a better option.
    May 2012
    #819
    Thank you sir for the quick reply, college student palang po ako kaya wala pong time pag detail ng mataggal. Any other brands sir na pwede gamitin instead of Turtle Wax? Ung isang apply lang po sana then wipe na agad, then patungan po ng Mothers FX Spray Wax. Color red po sir ung auto.
    #820
    kung red po yung car, use the Reflections Spray wax ng Mothers. the FX is much better for silver color shades. believe me... i know. 'learned from the experts here and PD.
Detailing Thread [For Newbies][continued 3]
