Page 4 of 127 FirstFirst 123456781454104 ... LastLast
Results 61 to 80 of 2535
    Oct 2008
    #61
    Quote Originally Posted by rico_g View Post
    I was planning to buy 3M IHG this weekend until I realized that I still have Moms step 2, i'm pretty sure it's no sealant, but i'm hoping that at least one of it's names got it right, that'd it'd be good enough as a glaze...
    .. Sealer and Glzae daw, eh di naman sealant, di rin glaze
    well.. question is is step 2 safe for new paint?
    the glaze seals the paint but allows it to gas out. body shop safe is said to have no wax nor silicones. this could also be effective to top on newly dried wax for people that are into that.
    Mother's step 2 is body shop safe. also, request for a few more passes of clearcoat
    Nov 2007
    #62
    Quote Originally Posted by indiej View Post
    what do you have on hand and what products can you avail? is your friend ready to do the weekly washing and take care of the work you've done afterwards?
    wash, and just because, kero, wash, clay, prewax, wax -- nano glos + sliq na muna. mostly in the newbie's guide to car appearance maintenance
    don't forget the wheel wells and wheels and tires and at least vacuum the car interior. and don't worry, the car will surely make a 180 turn towards shine and cleanliness.
    unless you know your stuff under the hood, simple muna sa engine detailing and give the utmost caution. clean and dress always with a cloth. wipe clean with a degreaser, wipe to dry, wipe on your dressing. avoid electrical connectors and sensors. ready a stick for hard to reach areas. no pressure. the result/feedback will reach the rest of your barkada
    good luck!
    thanks sa mga reply bossing...her only concern is to make her car clean and remove the minor scratches,see doesn't know about engine bay so hindi nya din maappreciate kung linisin ko ng todo,she told me na just concentrate on the exteriors...can the nano sliq and nano gloss can remove yung mga libag?i'll use elevo water mark remover sa glass,i also have plenty of MF towels
    Oct 2008
    #63
    Quote Originally Posted by john5 View Post
    pagkatapos ng claying, pwede ka rin dumiretso sa cleaner wax na final step. I haven't tried turtle wax to remove scratches but they say it can. you may also try scratchx after claying then wax afterwards. research mo yung tipo mong product. if feedback says it has cleaners, then it cuts the clearcoat and may remedy oxidation, swirls or scratches. nanoglos&sliq are not cleaners. if they say it has fillers, then it can hide scratches, maybe to a degree.
    best thing is to try your plan of attack on a square foot first. if you're not satisfied and you want to adjust, try on another. that way you can gauge the task/trouble in which you have put yourself
    magtagumpay ka sana. :gouste:
    Jun 2007
    #64
    as indiej suggested... magandang approach would be:
    1)wash
    2)clay
    tapos kung hindi natanggal ng clay yung mga libag
    3) cleaner wax
    -2 kinds: either chemical-based or abrasive. usually clearcoat safe yung chemical based, pero hindi to makakatanggal ng mga scratches.
    pwede ka gumamit ng mother's step 1 for your purposes
    happy detailing sir!
    ongapala, kung may mga aspalto, sprayan mo ng kerosene... lusaw yon. hehe.
    Mar 2005
    #65
    yung M80 pwede din sa new paint yun.
    Nov 2007
    #66
    ok mga boss...i'll take a pic on my corolla lovelife proj,nung isang araw yung d-max ng tropa ko tinira ko,removed minor scratches caused by a trike,a month ago my uncle's headlight and scratches din
    Oct 2008
    #67
    Quote Originally Posted by jmpet626 View Post
    jm, it's safer with M81, no wax.
    rico, if they sprayed ample clearcoat, chance to correct after 4-6 months. wala daw protection just gloss, but 3M IHG is a safe way to go. 3m wrote it on the IHG label. you could opt to not put anything.
    you could also ask how much to clearcoat the whole car.
    Mar 2005
    #68
    Pagkakaalam ko walang Wax yung m80 SpeedGlaze nung bagong repaint yung car ko m80 gamit ko for 2 months.
    http://www.meguiars.com/faq/index.cf...54&section=_54
    To maintain your cars fresh paint during the recommended curing time you can safely use any of the below Meguiar's pure polishes, which are not only safe for fresh paint but help to enhance the curing process while making your paint look it's absolute best.
    M-03 Machine Glaze
    M-05 New Car Glaze
    M-07 Show Car Glaze
    A-21 Deep Crystal Polish
    Another product you can use to maintain fresh paint throughout the curing process and even afterwards is Meguiar's M-80 Speed Glaze. Speed Glaze is a cleaner/polish that also contains a unique paintable polymer that will extend the durability of the product while offering protection to the finish closer to that of a real wax or paint protectant.
    Oct 2008
    #69
    eto kasi ang common sa mga waxes nila
    Isoparaffinic Hydrocarbon 64742-48-9 2-8 None 265-150-3 Xn; R-65
    m80 and prolly a21 or step2 (TS - trade secret) has this. the rest m03, m05, m07, m81 don't
    but they say it works which is the same with your experience so that's good to know.
    Jun 2010
    #70
    Will prolly stick to step 2 for now... Sayang naman kasi di na nagagamit... What do you mean by "chance to correct"? Meanin no corrections to be made for 4-6 months? So no cleaner waxes, polsihes or anything abrasive?
    Oct 2008
    #71
    not at all. with thicker clear coat, you just have more leeway to make corrections. if a product doesn't impede the gassing out during paint curing, generally it's ok. if you correct to perfection now but can't really protect as much, you'll just redo later and reduce more clearcoat (CC).
    that isoparaffin hydrocarbon is a synthetic solvent commonly used as a vehicle for insecticides. not a wax at all i guess. the lineup is green lighted by the manufacturer as jmpet proved. some of them have a bit of cleaners for maintenance/correction and shine of new paint, but offer minimal protection.
    finally, pics! does it look like murky water against the other detailed panels? hood pa naman-dapat baklas at may oven para flawless.
    Oct 2008
    #72
    i'm excited when there's an opportunity to add clearcoat, obviously none of our detailing products do that. 100ml of clear would add about 2 mils on the hood. how much is 100ml of CC compared to our sealants and waxes which aren't nearly as hard as the CC? what's better than 100ml? 200ml. there is a sweet spot as to how much to add on though. then we could be less jumpy than before about our CC and no more questions about depth of shine cos we know it Is deep. major corrections reduce about 0.5 mils at most.
    Nov 2007
    #73
    [quote=scharnhorst;1665136]*john5: got my dad a basic car care kit recently.
    eto binili ko for him:
    for washing:
    1)Washmitt
    2)Shampoo
    3)Chamois
    for waxing:
    1)Nanoglos
    2)applicator pad
    3)terry cloth
    for interior:
    1)sunshield
    2)terry cloth
    nakalimutan ko lang yung tireblack. hehe...
    eto ba yung gift pack ng microtex sa blade,499?
    Feb 2010
    #74
    mga sir, just waxed my car this afternoon, bakit ganon, everytime na lang pag nagbabuff na ko,lagi na lang may residue na natitira.. kailangan ko pa punasan ng ilang beses pa ulit para lang matanggal.. i used nanogloss.. same goes with my apc wax..
    Jun 2010
    #75
    Got my twins from the dojo kanina... too bad can't try it out yet... but i'm happy my arsenal is complete....
    thanks to master!!! salamat din dun sa 3M IHG!
    Oct 2007
    #76
    hi masters paturo naman pano gumamit ng 3m IHG. thanks!
    Jun 2005
    #77
    Guys, natuloy ba yung session kahapon? nagtext kasi si master ed nung saturday. sabi ni update niya ako pag tuloy kasi konti lang daw ata makakapunta. pero di nagupdate so i assumed di tuloy. is this in place of the FEB detailing session? wah!! T_T
    Nov 2007
    #78
    mga boss anong maganda at affordable na degreaser?TIA
    Jun 2007
    #79
    sir john, try mo d'best biodegreaser... available sa mga handyman stores.. 124 petot yung 500 mL spray bottle
    Jan 2011
    #80
    quick question, ano purpose ng terry towel ng microtex? pareho ba sila ng back-side ng plush? yung back-side kasi ng plush gamit ko for qd, mas madaling gamitin.
Detailing Thread [For Newbies][continued 3]
