*FasTrac: Haha this is going to be long but i'll see how far i can explain things and i'll explain the others after, i so need to go out right now to take my mind of things especially with what happened in my previous post.
Okay, lets start.
Basically there really are a lot of different kinds of pads.
Wool Pads no matter which kind, 4 ply wool, 2x twisted wool, No burn, and Foam wool are all used for serious paint correction. This is usually used with a Rotary polishe and with these kinds of pads its very easy to remove serious defects but its also easy to burn out or strike through the paint. But since its made for Rotary we won't get the much into this.
Then there's the Curved edge pads these are foam pads that have a curved edge very good for curvy cars and excellent for those with recessed curves. This pad is also mainly used for Rotary Polisher since only in using a Rotary would you be able to maximize its potential, if you use this on a DA then you would just end up like using its cheaper counter part the flat pads
Now under flat pads there's 3 kinds of pads that i know LC manufactures and these would be the one you would be looking for.
First there's the Flat pads, these pads are your standard generic pads and are the staple in most body shops. They are as it is described just a flat circular foam pad.
Second there the Flat pads with polish pockets, these pads are pretty much like the flat pads but have an inward curve in it, this helps in keeping the product you are using from slinging out when running at high speeds since its like enclosing the product in a foam cage. Using this pad could save you a little product but you have to prime it well to be able to use is properly.
Third is the CCS, these are a lot like the flat pads but its polish pockets are a lot smaller like the size of our 5 centavo coins distributed all throughout the pads they claim to save product but i have yet to notice if this really save products
Then there's also the kompressor pads, and kompressor pads also come in flat and curved edge shapes much like the ones i perviously describe the only difference is that with kompressor pads its like the pads are cut like very small rectangular cubes, the good thing about this is that in conforms to different surface and lessens heat build up, but the downside with the is that since its like cut into many many small rectangular cubes you actually end up using more products.
Okay, thats it for now, i'll continue my post regarding foam colors and regarding the compatibility with kp600 later, my BF is already downstairs and its time to enjoy the night. I'll try to continue late tonight.
