Results 11 to 16 of 16
April 16th, 2006 07:33 PM #11
"Topping up" is yesterday's tech. Newer vehicles don't require topping up. BMW's and other Euro vehicles have a sticker on the filler cap that prevents you from filling the cooling system and also for the dealer to know if you have tampered with the cover.
Cooling systems are now serviced in intervals as noted in the owner's manual. Losing a bit of coolant is normal so long as it does not go below minimum especially when the engine is already cold. Top ups are done during prescribed service intervals.
For most cooling systems, any ethelyne glycol based coolant blended in equal amounts with distilled water (minimal solids) works best. Check your particular vehicle's service intervals and coolant type.
As for the windshield washer, there are pre-mixed and concentrate forms available. Check what you are buying. Make sure they contain no materials that may harm your specific vehicle's finish.
YES. Tap water will work though it is not the ideal fluid for both cooling system and windshield washer applications. I've seen water pumps get ruined by running on pure tap [esp. the 'hard' variety] water.
As distilled water sold for battery applications are sometimes of questionable quality, the most ideal is still distilled drinking water.
April 17th, 2006 12:44 PM #12
Yup. I always use *shudder* Absolut or Wilkins for my older cars
mixed with coolant.
Tap water may seem okay, but lik OTEP says, people have had stuff fail because of dissolved minerals in the water. It's not usually a problem if you're the first owner of an old vehicle, but not good if you're pushing over 100,000 km already.
April 17th, 2006 02:54 PM #13
Originally Posted by OTEP
the doctor has spoken!
agree ako sa kanya... use wilkins or any brand distilled drinking water...both for radiator or windshield washer...although personally, sa radiator lang ako gumagamit ng distilled water. for windshield, pwede na tap water..wag lang deepwell water, leaves residues on the windshield when the water droplets dry (dissolved minerals). I don't think tap water will clog the windshield washer pipings unless super dumi nung tubig na kinarga mo. di naman naiinitan or kumukulo yung tubig sa windshield washer reservoir unlike yung sa radiator. just my 2 sentimos
April 17th, 2006 03:07 PM #14
Matagal ko na binabalak bilin ung windshield washer na nasa maliit na bote. "Windshield Washer" lang ata ung name nya, kulay blue sya. Concentrated ata. Try ko siguro pag umuulan na.
- Jun 2005
- 164
April 17th, 2006 03:50 PM #15ako hindi ko na tinitignan yung sa radiator at reservior. Bahala na casa dun...
sa windshield washer naman, distilled water lang. kasi nung bagong bili kotse ko nag marka sa paint yung nilagay ng casa.
Toyota is my choice
- Aug 2005
- 2,063
April 18th, 2006 09:53 AM #16Yeah... Same lng yan sila windshield and rad water.. distilled yan dba? u can buy that any sa gasoline stations..
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
