Results 1 to 10 of 16
April 16th, 2006 02:52 PM #1
question lang po.
i notice that many drivers use only water for the windshield wiper and sa radiator instead of using wiper fluid or coolant talaga. is this ok?
pasensiya na po. newbie lang sa pagdidrive
April 16th, 2006 03:15 PM #2
it's obvious, they're just drivers and don't own the car. May mga owners din who don't really know how to maintain their cars as long as it's running. I have a friend who doesn't know that the radiator has to filled with water.
April 16th, 2006 04:14 PM #3Originally Posted by carlos
April 16th, 2006 04:18 PM #4
coolant is there to prevent water on your radiator from boiling. and windshield washer fluids actually contain materials that could help remove dirt and grime from the windshield better than water. and besides, water may contain trace elements and deposits that could clog up your nozzle line...
April 16th, 2006 04:18 PM #5Originally Posted by wewoy_romero
April 16th, 2006 04:22 PM #6
ang coolant para sa radiator; ang windshield washer ay para sa windshield. Pag wala pakialam ang driver sa sasakyan, hindi sya driver.
April 16th, 2006 05:30 PM #7
Actually, it's best to use distilled water with a little wiper fluid mixed in for the wiper fluid reservoir.
Using plain tap water introduces scale into hoses and can lead to clogged windshield washers.
And a 50/50 mix of distilled water and coolant in the radiateor (dependent on manufacturer's specs)... but don't mix different types of coolant in the radiator at the same time, as there are certain coolants that react with each other.
Plain water causes quicker corrosion, and like aceshark said, lowers the boiling point of your system, making it less effective.
Some Redline water wetter added to your coolant reservoir is a pretty good idea, by the way.
April 16th, 2006 06:06 PM #8Originally Posted by niky
Is filtered drinking water or "inonized" water also ok? What does the wiper fluid have that make it special to use in lieu of 100% water? thanks
April 16th, 2006 06:13 PM #9Originally Posted by number001
Filtration won't filter out dissolved minerals so will still clog your nozzles.
April 16th, 2006 06:23 PM #10Originally Posted by Psylocke
Funny, all the cars/vehicles we had before all used garden-hose water and they all worked fine till the day they got sold.
sa Liwliw laguna maganda e test talaga yan.. meron sudden hairpin as in 72degree pa taas... wawa...
2023 Ford Everest Owners Thread
