Results 1 to 15 of 15
    Feb 2006
    Sir I need you help badly....
    Pinalinis ko radiator ko last month kc lagi sya nagbabawas ng tubig pag naka aircon pero if d ako naka aircon wla problem kahit long drive. nagbabawas pa rin sya ng water pag naka aircon.
    I tried to use coolant last saturday (50/50 mic with distilled water) pero nung na trapik ako sa cavite last sunday with aircon ON, almost 500ML and nilagay ko distilled water.
    pero nung bumalik ako pa pasig wla n trapik konti lang lagay ko tubig.halos d nga nabawasan.
    Balak ko sana pa upgrade ng 3 rows ung radiator kc pupunta kami bicol this coming saturday....pls help
    Model: Lite ace 92
    radiator: 2 rows (daw) d ako sure e.
    tnx mga bro
    bro.... ano question?
    Feb 2006
    Quote Originally Posted by happy_gilmore
    Bro san b nakakabili ng 3 rows na radiator d2? nag babawas kc ng tubig ung radiator ko pag naka aircon.. uwi p nmana kamai ng bicol this saturday.
    just edited the thread title.
    kindly use appropriate titles to suit your problem to avoid confusion.
    Feb 2006
    Quote Originally Posted by mazdamazda
    ok sir, sorry for the mess... btw, do u have any idea kung san po may naagpapalit ng radiator to 3 rows? kindly advice
    ayun maliwanag na....
    ano oto mo? tsaka san location mo? saw a 3 row radiator last saturday sa minerva tire, filinvest alabang.
    Feb 2006
    Toyota lite ace bro.... ung 3 row n nakita mo pang lteace kya un?
    I heard n meron daw evercool sa may bandang south na nag momodfy ng radiator san kya un?
    Aug 2004
    Lite Ace ba ito? I'd suggest upgrading your cooling capacity first... ganoon din ang problem ng first generation Vanettes. If the Liteace has only one cooling fan, I'd suggest installing an additional auxiliary fan wired to turn on when you use your AC.
    Feb 2006
    Quote Originally Posted by niky
    Yup lite ace po ito... Meron n additional auxiliary fan and connected to both radiator and condenser. Nag try n din ako gamit ng coolant pero I noticed na pag na trapik k ng almost 1 hour d nman sya nag ooverheat pero noticed ko lang almost haf liter ung naubos nyang tubig...pero pag d k nman naka aircon wla problem...as in halos d nagbabawas....
    Aug 2004
    hmmh, barado kaya AC condenser mo? Also check that your fans are blowing full speed. Minsan mukhang okay pero di pala.
    nag babawas ang tubig? di ba talaga naman nag eexpand ang tubig pag mainit pumupunta sa reservoir yun pero dapat babalik pag cool down baka sira na yung hose mo papuntang reservoir
    Feb 2006
    Quote Originally Posted by fierari
    oo nga sir, napansin ko kc ung reservoir parang puno na.cge sir try ko chk ung hose mukang d nga bumabalik ung tubig from reservoir to radiator.
    Anyway, ok kya na i upgrade ko ung radiator ko into 3 rows? Kinakabahan 2loy ako bka itirik ako neto sa saturday kc bakasyon ako 1 wik sa bicol...layo p nman ng byahe ko.and ask ko din sana, last saturday kc nag drain ako ng radiator and lagay ako coolant (50/50 with distilled) 3 liters ung lagay ko, meaning b nun 2 rows sya? ano b capacity ng 3 rows na radiator? pls advice tnx in advance
    Jan 2003
    sir, check also ur radiator cap. its possible that when the a/c is on the temp gets higher and the rad cap cant withstand the pressure so the water is dislodged out (not only to the reservoir). check the gasket, better yet, buy a new cap. mtcw.
    Feb 2006
    tnx conzky try ko din...palitan, pare pareho lang ba size ng radiator cap?
    Feb 2006
    mali yta nabili ko n cap d sya fit sa radiator ko dba meron 2 ung specs?
    ung dati nya kc 0.9kg/cm lang nkikita ko.
    ano kya fit para sa liteace?
3 Row Radiator [Renamed]
